100% or 90%
100% or 90%
Postby son0rous » Thu Dec 11, 2003 9:57 pm
100% Load
Pro: Get work unit done faster.
Con: CPU Temps
Con: Programs open slightly slower
90% Load
Con: Get work unit done slightly slower.
Pro: Lower CPU temps
Pro: No effect at all on computer speed due to the buffer zone.
Your decision: Keep it at 100%, whereby getting things done faster and increasing your score, or dropping it 10% and have your computer run as it would if you had never heard of folding.
There are ways around this though. Just do some mild overclocking. Say you have a 3.0Ghz computer, and drop it to 90%, meaning F@H is using 2.7Ghz. All you have to do is overclock it 11% and you will be folding at your once 100% level without losing any performance at all.
son0rous
Postby Tulatin » Thu Dec 11, 2003 9:59 pm
I say 100% and get some more ram. With 1.0 gb, dual channel, no program delay or lag at all with F@H.
Tulatin
Postby son0rous » Thu Dec 11, 2003 10:03 pm
i dont see the purpose of buying a gig if i dont use it
son0rous
Postby Tulatin » Thu Dec 11, 2003 10:04 pm
rather true. The only diffs i've seen so far is video encoding is a bit faster, and audio encoding is rediculousally fast (5% in about a minute, on an hour long file)
Tulatin
Postby dougsherwood1320 » Fri Dec 12, 2003 3:06 pm
I had a stick of 256meg go bad on me and I had to run with only 256meg. Slowed everything :cry:
Now I have a 128meg and a 256meg in the system until I get the other back from RMA, at which time I will be back to 512meg. The extra 128meg makes a huge difference since I do a lot of multitasking.
I will bump it up to 1gig after the first of the year just to give me headroom.
SOME THINGS MUST BE BELIEVED TO BE SEEN
MEMBER- MOTHERBOARDS.ORG FOLDING TEAM
>>>>>>>>>1,000,000 POINTS<<<<<<<<<
dougsherwood1320
Postby CDBurner » Fri Dec 12, 2003 5:27 pm
I've got 1 GB of RAM in my AthlonXP 2000+ computer (which I use for folding), and I notice very little performance decrease while F@H is running at 100%.
CDBurner
Postby profofpcs » Fri Dec 12, 2003 8:46 pm
the machine in my sig is just fine for folding and everything else at the same time. i dont experience any slow downs. even the thrown together machine(albatron kx400-8x with 128Mb ram and win2k) is running great with almost no slow downs. both these run f@h 24/7 and i still internet both of them on a daily basis.
profofpcs
Postby son0rous » Fri Dec 12, 2003 8:50 pm
strange, i was noticing some rather annoying ones on mine when opening large apps
son0rous
Postby Tulatin » Sun Dec 14, 2003 2:42 pm
IT may be something to do with the drive or windows then. Time for a defreag and tweaking.
Tulatin
Postby son0rous » Sun Dec 14, 2003 3:38 pm
i defrag a minimum of once a day using either voptxp, O&O, or diskeeper
son0rous
