Can I send in an incomplete unit
Postby Pette Broad » Wed Dec 10, 2003 8:03 pm
I've decided to cease folding with the P2 333. It's just too slow, so I'm going to replace it with a Duron 1600 that I just got. It's done 128/400 in 9 days, takes 50 mins to do a frame. Can I abandon it and send it in as an incomplete, must be worth a few points. How do I go about it?
Thanks
Pete
Pette Broad
Re: Can I send in an incomplete unit
Postby len444 » Wed Dec 10, 2003 9:07 pm
Pette Broad wrote:I've decided to cease folding with the P2 333. It's just too slow, so I'm going to replace it with a Duron 1600 that I just got. It's done 128/400 in 9 days, takes 50 mins to do a frame. Can I abandon it and send it in as an incomplete, must be worth a few points. How do I go about it?
Thanks
Pete
can't send in partial wu's. copy the work folder, and queue.dat file, and paste into the FAH directory of the duron machine. with a little luck, you'll be able to resume folding right where it left off (should work).
len444
Postby Pette Broad » Wed Dec 10, 2003 9:33 pm
Len,
Hey, that's neat, should have thought of that myself really :oops: I have already upgraded a few chips in mid WU and they got sent out O.K. Should boost us up at least 500 points per month!!! 8)
Thanks
Pete
Pette Broad
Postby Pette Broad » Thu Dec 11, 2003 3:53 pm
Len,
Worked fine.
Cheers,
Pete
Pette Broad
Postby len444 » Thu Dec 11, 2003 4:20 pm
hope you redid the config, or it'll be annonymous!?! :idea:
len444
Postby Tulatin » Thu Dec 11, 2003 5:50 pm
yeah, hopefully it's configed proper, and the transplant worked correct?
Tulatin
Postby Pette Broad » Thu Dec 11, 2003 6:11 pm
Len444 wrote:hope you redid the config, or it'll be annonymous!?! :idea:
Yeah, the first thing it did was ask me to connect up. It wouldn't run till I did. I'll check and see what it says.
Pete
Pette Broad
Postby Pette Broad » Thu Dec 11, 2003 6:15 pm
Tulatin wrote:yeah, hopefully it's configed proper, and the transplant worked correct?
I think so, it resumed at 129/400, guess I'll find out in a couple of days :)
Cheers,
Pete
Pette Broad
Postby len444 » Thu Dec 11, 2003 8:42 pm
you must redo the config w/ your name, and team 33258 (right click systray icon, or use -config flag w/ console version). the old config was left w/ your other machine. folding will run w/ o a config, though you won't get any credit for it when it's handed in. :idea:
len444
Postby Pette Broad » Thu Dec 11, 2003 8:51 pm
O.K, I've done that, and my name and Team No are showing up in the log too.
Thanks,
Pete
Pette Broad
