What's happened here?
Postby Pette Broad » Wed Dec 03, 2003 6:30 pm
WU was at around the 280 mark when suddenly it asked to connect. It stayed connected for a few seconds, then another message popped up saying it was O.K to close the connection..It then started on a new WU and couldn't possibly have sent or received anything significant in the 10 seconds or so it requested. Also for some reason, my 2nd WU from last week didn't get sent until I finished the 3rd one then they both got sent together. Is this normal?
Pete
Does this mean I lost it :(
[17:59:39] Finished a frame (277)
[18:07:29] Finished a frame (278)
[18:14:40] Finished a frame (279)
[18:18:59] CoreStatus = 1 (1)
[18:18:59] Client-core communications error: ERROR 0x1
[18:18:59] Deleting current work unit & continuing...
[18:19:03] + Attempting to get work packet
[18:20:50] - Connecting to assignment server
[18:20:52] - Successful: assigned to (171.64.122.143).
[18:20:52] + News From Folding@Home: Welcome to Folding@Home
[18:20:52] Loaded queue successfully.
[18:21:00] + Connections closed: You may now disconnect
[18:21:05]
[18:21:05] + Processing work unit
[18:21:05] Core required: FahCore_65.exe
[18:21:05] Core found.
[18:21:05] Working on Unit 05 [December 3 18:21:05]
Pette Broad
Postby dharbert » Wed Dec 03, 2003 6:41 pm
Yep, you lost it.
dharbert
Postby len444 » Wed Dec 03, 2003 6:47 pm
you should post this at the FAH forums under the bug reporting section. anything that gets deleted does mean that you do not get any credit for it. best to use the -verbosity 9 flag for maximal output to fahlog.txt file- which can be especially handy during trouble shooting errors.
len444
Postby Tulatin » Wed Dec 03, 2003 6:55 pm
well, either that's a bad bug, a damaged work unit, or a timered checkpoint.
Tulatin
Postby Pette Broad » Wed Dec 03, 2003 8:56 pm
O.K, Just had another one bomb out after 15 or so units on another computer. This one has at least gone into the upload work queue
Cheers,
Pete
Pette Broad
Postby Tulatin » Wed Dec 03, 2003 8:58 pm
To force the ones in quoqe to upload, just fire up the client with the -sendall flag, and then re-start it without the flag once it's done.
Tulatin
Postby Pette Broad » Wed Dec 03, 2003 9:16 pm
O.K, Tul, I'll do that.
Thanks,
Pete
Pette Broad
Postby Tulatin » Wed Dec 03, 2003 9:16 pm
Welcome, and good luck.
Tulatin
Postby len444 » Wed Dec 03, 2003 9:40 pm
reference the flags list:
http://www.stanford.edu/group/pandegrou ... guide.html
if using the latest beta, then consult the changelog for new flags.
len444
