It is currently Sat Jun 06, 2020 6:16 pm
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Tue Dec 02, 2003 3:29 pm
That's true. Just be sure to keep the wires somewhat orderly... and thanks, and good luck!
PostPosted: Tue Dec 02, 2003 5:47 pm
No problem. Just got a 4th Machine Running an XP1600. Found several phone splitters and a few cables...so onto the next one :)
Cheers,
Pete
PostPosted: Tue Dec 02, 2003 5:48 pm
i can see this taking a while... what are you going to do if a machine randomly dials on whoile you're on the phone?
PostPosted: Tue Dec 02, 2003 5:53 pm
I've ticked the "Ask Before Using Network" box in the options. That worked on this machine, should work on the others too..I hope.
Cheers,
Pete
PostPosted: Tue Dec 02, 2003 5:54 pm
should, but you'll have to keep an eye on it
PostPosted: Tue Dec 02, 2003 6:09 pm
Heh, heh, good job they don't finish like 3 times a day :) Seriously though, there won't be a problem, I don't have to go out to work and they get switched off at night. Can easily keep tabs on say 8 machines. Will keep you updated as I setup further machines. Am going to move my faster computers close up to the phone lines over the next couple of days.
Cheers,
Pete
PostPosted: Wed Dec 03, 2003 10:18 am
did you verify the md5sum of the downloaded *.iso before burning it?
