It is currently Sun Jan 26, 2020 7:59 pm
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri Nov 07, 2003 11:52 am
not much speed change. there are some features added. for linux distros, it'll now work w/ the newer glibc libraries above 2.3.1 (but still is problematic w/ at least 1 glibc library). if you've run relatively trouble free so far, there probably isn't much of a benefit. if you have an 8 cpu server, or want to run the newer linux distros, then it might be. i was apprehensive at first, but now have the v4.00 installed on all my linux based comps, and seems to run ok so far. it might be best to wait, unless there is a specific feature that it has (that you need). here's the changelog:
http://www.stanford.edu/group/pandegrou ... hanges.txt
the biggest point of confusion will probably come from redefining -forceasm flag to mean 3dnow!+ optimizations, and -forceSSE to mean sse optimizations w/ AMD cpu's. i think -forceasm still means sse optimizations w/ p4 cpu's though. :?
PostPosted: Fri Nov 07, 2003 12:18 pm
right lenn...both pretty much work with intels. i run all the switches though.. AMD's MUST run the -forceSSE to get the sse boost...otherwize you just get the 3DNOW! boost, and from what i've read, i guess that's really not that great. ya want to tap into the SSE!
Default_Dave's STATS! Team #33258
PostPosted: Fri Nov 07, 2003 12:38 pm
i just found out that the ask before send setting now works in linux console. i just checked on one of my comps, and it was waiting for a c (connect) key press command to send the wu in. it was sitting idle for ~7hrs :o but i had to test, and verify if the setting would work or not! great for setting up a comp for maintenance after crunching is completed. instead of pressing c to connect, close the console, and restart w/ the -send all flag.
PostPosted: Sun Nov 09, 2003 1:07 pm
There is a speed boost yes; but you don't see it all the time.
