It is currently Tue Oct 27, 2020 5:01 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Sat Nov 01, 2003 1:20 pm
Ok southwind25, I say this not to attack or upset you in any way, just to be informative. When doing #681, it is a tinker, 400 frames, and 30.1 points, 2 minutes per frame. Now I amdoing #678, is a tinker, 400 frames, and 70.9 points, and a frame ever 5 minutes. So your 2 minutes per frame is about on par with my 5 minutes per frame. Since my work unit is aprox. 2.4 times more points with the same amount of frames. I am no longer at 2.3GHZ anymore either, had a sudden heat wave and I couldn't keep it stable. So I'd say we are both folding about the same. The purpose of this post :?: I was getting worried that I was folding poorly, so I just wanted to straighten it out.
I have a belly button
PostPosted: Sat Nov 01, 2003 1:31 pm
Danny ,
If you go back and reread my first post in this tread, I said I thought you were doing ok, because it was turning out about the same work my 2500+ was overclocked about the same amount. I take no offense to what you just said, besides if you double both my time and points to 4 minutes a frame and 60 points, I'm still doing ok :wink:
PostPosted: Sat Nov 01, 2003 1:37 pm
Well like I said, our processors are like exactly the same, and I am glad to see that we are folding the same that's all :D. I mean, wouldn't it suck if we had the same procs OC'd to the same amount, yet were totally out of sync!!!
PostPosted: Sat Nov 01, 2003 4:54 pm
The theory of point to speed ratio is bunk. I've had a 3 point tinker take days, while a 50 point tinker taking hours.
PostPosted: Sat Nov 01, 2003 4:56 pm
Well it worked this time...
PostPosted: Sat Nov 01, 2003 4:57 pm
Maybe just this time. You never know. We should also work out ratios for this.
PostPosted: Sat Nov 01, 2003 8:09 pm
Yup.
