It is currently Mon Mar 30, 2020 6:13 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sat Nov 01, 2003 12:27 am
miki, i checked your stats, and you seem to be handing in full valued wu's:
http://folding.extremeoverclocking.com/ ... erID=60626
reference wu's here:
http://folding.stanford.edu/psummary.html
PostPosted: Sat Nov 01, 2003 12:28 am
Len - am i ahead of him just beacuse of luck (higher point value work units) or does it not add up?
PostPosted: Sat Nov 01, 2003 3:49 am
Len, if I handed complete all the WUs, then where do you things might go wrong? Because I think there must be something wrong in my point scoring? I haven't set any of the switches suggested by Tulatin. Do you think those switches might help with the point scoring?
Help humanity .....join the
Motherboards.org
folding team! 33258
PostPosted: Sat Nov 01, 2003 10:19 am
Southwind25 wrote:
I finally got my Barton sorted out. I'm doing a tinker on it too. It's running at 2200 mhz and doing a frame every 4 miuntes and 35 seconds, so I'd say your's was performing about where it should be Danny. Len, I'm running the graphical version and I can't seem to find the point values for WU's. What should a 400 frame tinker be worth?
I was wrong when I made that statement. I had a video driver that was corrupt and it caused me to start and prematurelyabort 2 work units before I got it strightened out. I do have it fixed now I think. It's doing a tinker at about a frame every two minutes now:
01:32:04] PROJECT="work/wudata_01", NSTEPS=5000000, DT=2.0000, DTDUMP=25.000000, TEMP=296.00
[01:32:04] TINKER: Software Tools for Molecular Design
[01:32:04] Version 3.8 October 2000
[01:32:04] Copyright (c) Jay William Ponder 1990-2000
[01:32:04] portions Copyright (c) Michael Shirts 2001
[01:32:04] portions Copyright (c) Vijay S Pande 2001
[01:34:11] Finished a frame (1)
[01:36:18] Finished a frame (2)
[01:38:25] Finished a frame (3)
[01:40:32] Finished a frame (4)
[01:42:39] Finished a frame (5)
[01:44:46] Finished a frame (6)
[01:46:53] Finished a frame (7)
[01:49:00] Finished a frame (8)
[01:51:06] Finished a frame (9)
[01:53:18] Finished a frame (10)
[01:55:31] Finished a frame (11)
[01:57:40] Finished a frame (12)
[01:59:50] Finished a frame (13)
[02:03:23] Finished a frame (14)
[02:05:58] Finished a frame (15)
[02:08:08] Finished a frame (16)
[02:10:15] Finished a frame (17)
[02:12:21] Finished a frame (18)
[02:14:29] Finished a frame (19)
[02:16:36] Finished a frame (20)
[02:18:43] Finished a frame (21)
[02:20:50] Finished a frame (22)
[02:22:57] Finished a frame (23)
[02:25:04] Finished a frame (24)
[02:27:11] Finished a frame (25)
[02:29:14] Finished a frame (26)
[02:31:14] Finished a frame (27)
[02:33:15] Finished a frame (28)
[02:35:15] Finished a frame (29)
[02:37:16] Finished a frame (30)
[02:39:16] Finished a frame (31)
[02:41:17] Finished a frame (32)
[02:43:17] Finished a frame (33)
[02:45:17] Finished a frame (34)
[02:47:18] Finished a frame (35)
[02:49:18] Finished a frame (36)
[02:51:19] Finished a frame (37)
[02:53:19] Finished a frame (38)
[02:55:20] Finished a frame (39)
[02:57:24] Finished a frame (40)
[02:59:26] Finished a frame (41)
[03:01:29] Finished a frame (42)
[03:03:29] Finished a frame (43)
[03:05:29] Finished a frame (44)
[03:07:28] Finished a frame (45)
[03:09:28] Finished a frame (46)
[03:11:28] Finished a frame (47)
[03:13:27] Finished a frame (48)
[03:15:27] Finished a frame (49)
[03:17:27] Finished a frame (50)
[03:19:26] Finished a frame (51)
[03:21:26] Finished a frame (52)
[03:23:25] Finished a frame (53)
[03:25:25] Finished a frame (54)
[03:27:24] Finished a frame (55)
[03:29:24] Finished a frame (56)
[03:31:23] Finished a frame (57)
[03:33:23] Finished a frame (58)
[03:35:22] Finished a frame (59)
[03:37:22] Finished a frame (60)
[03:39:21] Finished a frame (61)
[03:41:21] Finished a frame (62)
[03:43:20] Finished a frame (63)
[03:45:20] Finished a frame (64)
[03:47:19] Finished a frame (65)
[03:49:19] Finished a frame (66)
[03:51:18] Finished a frame (67)
[03:53:18] Finished a frame (68)
[03:55:17] Finished a frame (69)
[03:57:17] Finished a frame (70)
[03:59:16] Finished a frame (71)
[04:01:16] Finished a frame (72)
[04:03:15] Finished a frame (73)
[04:05:15] Finished a frame (74)
[04:07:14] Finished a frame (75)
[04:09:14] Finished a frame (76)
[04:11:13] Finished a frame (77)
[04:13:13] Finished a frame (78)
[04:15:12] Finished a frame (79)
[04:17:12] Finished a frame (80)
[04:19:11] Finished a frame (81)
[04:21:11] Finished a frame (82)
[04:23:10] Finished a frame (83)
[04:25:10] Finished a frame (84)
[04:27:09] Finished a frame (85)
[04:29:09] Finished a frame (86)
[04:31:08] Finished a frame (87)
[04:33:08] Finished a frame (88)
[04:35:07] Finished a frame (89)
[04:37:07] Finished a frame (90)
[04:39:06] Finished a frame (91)
[04:41:05] Finished a frame (92)
[04:43:05] Finished a frame (93)
[04:45:04] Finished a frame (94)
[04:47:04] Finished a frame (95)
[04:49:03] Finished a frame (96)
[04:51:03] Finished a frame (97)
[04:53:02] Finished a frame (98)
[04:55:02] Finished a frame (99)
[04:57:01] Finished a frame (100)
[04:59:01] Finished a frame (101)
[05:01:00] Finished a frame (102)
[05:03:00] Finished a frame (103)
[05:04:59] Finished a frame (104)
[05:06:59] Finished a frame (105)
[05:08:58] Finished a frame (106)
[05:10:58] Finished a frame (107)
[05:12:57] Finished a frame (108)
[05:14:57] Finished a frame (109)
[05:16:56] Finished a frame (110)
[05:18:56] Finished a frame (111)
[05:20:55] Finished a frame (112)
[05:22:55] Finished a frame (113)
[05:24:54] Finished a frame (114)
[05:26:54] Finished a frame (115)
[05:28:53] Finished a frame (116)
[05:3
PostPosted: Sat Nov 01, 2003 12:01 pm
I believe it's because i've handed in higer value work units - mostly grommacks.
Here's what my point counter should be.
Project WU
320 1 - 51.40 points
332 2 - 51.40 points (102.80 points)
363 1 - 54.60 points
372 1 - 53.30 points
382 1 - 53.30 points
572 1 - 47.00 points
611 1 - no longer listed. Probably aa 1-5 point tinker
638 1 - 70.90 points
648 1 - no longer listed. Probably a 1-5 point tinker
682 1 - 30.10 points
11 Work Units, 465.40 +/- 10 points
My counter is at 489.
PostPosted: Sat Nov 01, 2003 12:50 pm
I think it depends mostly on the type of WU. Because when there is a 30 point wu with 2500 frames, you will be doing frames very quickly. So which # were you doing while getting a frame every 2 minutes southwind?
I have a belly button
PostPosted: Sat Nov 01, 2003 12:53 pm
Ah! now I am doing a frame every 5 minutes!
PostPosted: Sat Nov 01, 2003 12:57 pm
It was WU# 681. It was a 400 frame tinker wu. I'm running a Gromac WU #344 now and it doing 5000 steps(1%) every 11 minutes.
PostPosted: Sat Nov 01, 2003 1:09 pm
We need to begin composing an average of speeds for work units.
PostPosted: Sat Nov 01, 2003 1:17 pm
It's hard to be very exact with all the variables involved, but I've Folded with machines from a SlotA 900 T-Bird to the 2500 Barton and horsepower does make a difference. I haven't had the Barton overclocked but since yesterday, but I can see a huge difference between it an an O/C ed 1700 I have on the same desk.
