It is currently Sat Apr 04, 2020 1:39 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Is this slow?
PostPosted: Thu Oct 30, 2003 10:58 am
I am doing a frame every four minutes. Is this slow or what? I really do not know.
I have a belly button
PostPosted: Thu Oct 30, 2003 11:01 am
Also, it is a tinker.
PostPosted: Thu Oct 30, 2003 11:11 am
as wu's vary depending on what protein series is being evaluated- please state what protein# wu you're currently working on!
currently running projects are stated here:
http://folding.stanford.edu/psummary.html
PostPosted: Thu Oct 30, 2003 11:16 am
I am doing 692.
PostPosted: Thu Oct 30, 2003 11:24 am
danny the bum wrote:
I am doing 692.
i'm working on the same tinkers myself. i have an overclocked athlon xp t-bred B 1800+ at xp2200+, and it's getting about ~6.5min/ frame, an athlon xp2100+ (no OC) that's getting 7.5min/ frame, and an athlon xp 1500+ OC'd to 1600+ that is getting ~9.5min/ frame. i would say ~4min/frame is a pretty decent frame rate. is this machine the one in your sig, and is the OC the same?
PostPosted: Thu Oct 30, 2003 11:43 am
Yes, it is exactly the same as in the sig.
PostPosted: Thu Oct 30, 2003 11:56 am
i hope to be seeing 70.9 points in your stats when the wu is handed in!
stats reference here:
http://folding.extremeoverclocking.com/ ... amID=33258
PostPosted: Thu Oct 30, 2003 12:25 pm
You will, don't worry.
PostPosted: Fri Oct 31, 2003 12:42 pm
I finally got my Barton sorted out. I'm doing a tinker on it too. It's running at 2200 mhz and doing a frame every 4 miuntes and 35 seconds, so I'd say your's was performing about where it should be Danny. Len, I'm running the graphical version and I can't seem to find the point values for WU's. What should a 400 frame tinker be worth?
PostPosted: Fri Oct 31, 2003 4:54 pm
Yeah, that's a good speed. That's about as good as you'll get with today's h/w.
