It is currently Mon Feb 24, 2020 12:30 am
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri Oct 31, 2003 9:16 pm
if folding slow is a problem, perhaps the core is bad. stop folding delete the core, and when you restart, it'll download a new core. this might help, though it might not. it's worth a try though.
maxing performace is good. just running the program and helping out is good too.
btw, i have a comp that uses the -advmethods -forceasm -verbosity 9 flags (all three comps config'd the same). i haven't touched it, and it's back doing a gromacs wu. keep the flags, and run the wu's. if Stanford hands out tinkers, then that's what's on the menu.
PostPosted: Fri Oct 31, 2003 9:18 pm
I've gotten a few tinkers with these flags in place, and it's no trouble, so long as it's not one of the stupid 1 point ones.
PostPosted: Fri Oct 31, 2003 10:05 pm
Yea, that worked for me, the F@H was extremely unstable, then Len444 suggested I redownload at a non-overclocked state. Worked like a charm 8)
I have a belly button
PostPosted: Sat Nov 01, 2003 3:07 pm
and install non OC'd. pretty much a general rule in installing any software.
PostPosted: Sat Nov 01, 2003 4:51 pm
I install just about everything overclocked on my part - not one issue yet, and my fah runs perfect.
PostPosted: Sat Nov 01, 2003 9:40 pm
there's always going to be a variation of what you can get away with. general rules are just that- a generalization. i've helped a couple of people so far by asking if OC'd, and to drop it- and most in that respect had things work out better by doing so. universal advice for a broad spectrum of pc builds (and many variables relevant to motherboards, cpu's, memory modules, ram timings, cpu temps/ ventilation, ect...).
PostPosted: Sat Nov 01, 2003 9:42 pm
True. Each situation will have it's variables and end up with different results.
