It is currently Sun Oct 21, 2018 3:29 pm
PostPosted: Wed Oct 29, 2003 12:36 pm
I have a hardware profile for gaming which basically only starts the services that i need to run windows. Thing is, WinFAH still runs at startup and i cant seem to find it in the services list. Can anyone help me?
CPU=AMD Athlon X2 3800+
RAM=Corsair XMS DDR400 1GB 2-3-3-6 Timings
MOBO=ASUS A8N-E
VID=EVGA GeForce 7950GT
HDD=74GB WD Raptor
PostPosted: Wed Oct 29, 2003 5:27 pm
unless you specificaly run folding as a 'service' you will not find it in the list (nativly it's not a service). you'll find it either in the "start up" in start menu's program list or if not there it's in the "Run" key in the registry.
why stop it though? i run (4) client(s) thru everything... even video rendering/encoding, DVD burning, everything.
but look in those spots for the shortcut or patch
Default_Dave's STATS! Team #33258
PostPosted: Wed Oct 29, 2003 5:53 pm
4 clients at once? no wonder youre the head of the team!
MOBO=ASUS A8N-E
HDD=74GB WD Raptor
PostPosted: Thu Oct 30, 2003 2:20 am
You can setup the client to run as a program at startup, as a clickable shortcut, or as a service.
So it can appear as a service, or as a running application depending on how you installed it, and/or if it is running at the time.
PostPosted: Thu Oct 30, 2003 6:24 pm
Ah so it was in the install. Its fine. I can simply pause F@H when i want to play MP2.
MOBO=ASUS A8N-E
HDD=74GB WD Raptor
