It is currently Mon Jan 21, 2019 2:29 pm
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Wed Oct 29, 2003 5:34 pm
Len444 wrote:
pretty sure you're running as a service (if i remember correctly), so i wonder if you need to perform a reboot to get folding going? i haven't run folding as a service yet, so i'm not hands on experienced in that specific regard.
if you just pull up a command prompt an type
Code:
 net stop <service_name>
you can stop and start the service (either that or use the gui service list). i think this will prevent a reboot. :wink:
Default_Dave's STATS! Team #33258
PostPosted: Wed Oct 29, 2003 6:33 pm
Code:
<service_name> are the brakets used or not (i'd assume not)?
PostPosted: Wed Oct 29, 2003 7:04 pm
yep it is running as a servise and no need to reboot . as for deleting the fahcore65.exe , is that the only one i've got to delete :?:
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
radeon 7000 64mb w/tv out
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
PostPosted: Wed Oct 29, 2003 8:44 pm
Your 250 and your 2500 are the same. Just 250 will advance by 5 while 2500 at 50. Also, this is like 500s. They're all really just grommack 100s.
PostPosted: Thu Oct 30, 2003 8:40 am
Quote:
just curious, how much L2 cache does the PIII550 have?
512K
My 250 seems to go in increments of 2. This morning when I checked it, it was at 152/250.
Phenom II X6 1055T @ 2.8GHz
Dual Boot Win7x64/Bodhi
8 GB RAM
Radeon HD 3450
60GB Vertex 2 SSD (For OS's)/750GB for Data
PostPosted: Thu Oct 30, 2003 10:52 am
JC GARCIA wrote:
well i'm only getting tinkers at the moment .
and i have 3 machines that are all getting tinker wu's at this very moment. i tried to wipe all files except for the 3.25 beta console executable, but this still resulted in a tinker being downloaded. just let them run. it's what they are giving out.
PostPosted: Thu Oct 30, 2003 2:48 pm
ok will do :wink:
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
PostPosted: Thu Oct 30, 2003 3:12 pm
Len444 wrote:
Code:
this is correct lenn. sorry the vague discription. in this case yes, if you called the service Folding then
Code:
net stop Folding
net start Folding
will stop and start the service.
BUT two word service names need quotes around it. like the WINS Client service would be
Code:
 net stop "WINS Client"
net start "WINS Client"
PostPosted: Thu Oct 30, 2003 6:27 pm
Just got a tinker here too.... Maybe the grommacks supply is drying up? As to this tinker, i did 25% in 8 hours.
PostPosted: Thu Oct 30, 2003 6:49 pm
what protein number :?: and 25% in 8 hours is actually quite good rate :wink:
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
