250 Blocker?
250 Blocker?
Postby steve6787 » Wed Oct 29, 2003 9:14 am
After finishing my 2500 blocker last night, I received a 250 Blocker. I have never had one of these and its taking foooorrreeevveeerrr to complete! It started around 6PM last night and as of this morning, around 6:15AM, it was only at 50/250. Looks like I got a tinker, but never received one that was 250. I have the -forceasm and -advmethods flags. I have received a few 500 blockers that take a good bit of time also....
Phenom II X6 1055T @ 2.8GHz
Dual Boot Win7x64/Bodhi
8 GB RAM
Radeon HD 3450
60GB Vertex 2 SSD (For OS's)/750GB for Data
steve6787
Re: 250 Blocker?
Postby len444 » Wed Oct 29, 2003 10:33 am
steve6787 wrote:After finishing my 2500 blocker last night, I received a 250 Blocker. I have never had one of these and its taking foooorrreeevveeerrr to complete! It started around 6PM last night and as of this morning, around 6:15AM, it was only at 50/250. Looks like I got a tinker, but never received one that was 250. I have the -forceasm and -advmethods flags. I have received a few 500 blockers that take a good bit of time also....
one way to tell what wu type you have, is to reference the currently running projects page:
http://folding.stanford.edu/psummary.html
there are new 10XX series wu's, so it's possible you have one of these. it helps to run the verbosity 9 flag, as it will show the ip address that the wu came from, and then you can reference the server status page:
http://folding.stanford.edu/serverstat.html
if i remember correctly, you changed from an amd k62-400, to a pIII 500 (not sure on the pIII mhz). how are things going w/ the pIII? does the fahlog.txt file show "extra sse boost ok" when a wu is initiated?
len444
Postby steve6787 » Wed Oct 29, 2003 11:13 am
I actually do have the verbosity 9 flag running, I forgot to include that in the list of flags Im using.
Im running a PIII 550, and its running great. Folds a lot quicker. Took 15-20 days on a 500 blocker with the K6-2 400 and 2-3 days on a 500 blocker with PIII. Yes, It does say "extra sse boost ok" in the fahlog.txt
Also, thanks for the links!
8 GB RAM
Radeon HD 3450
steve6787
Postby len444 » Wed Oct 29, 2003 11:54 am
what WU are you currently working on?!?
extra sse boost ok- rock on!
is stability ok?
len444
Postby J.C.GARCIA » Wed Oct 29, 2003 2:33 pm
just a small note . from what i've noticed the wu's that use the fahcore65 dont have any boost like the extra sse boost . has anyone noticed this :?:
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
radeon 7000 64mb w/tv out
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
J.C.GARCIA
Postby len444 » Wed Oct 29, 2003 3:05 pm
J.C.GARCIA wrote:just a small note . from what i've noticed the wu's that use the fahcore65 dont have any boost like the extra sse boost . has anyone noticed this :?:
that's a good observation. this is because the tinker wu's (fahcore_65.exe) don't use "assembly code" optimizations. sse, and 3dnow! are assembly optimizations, and can only be utilized by gromacs wu's (fahcore_78.exe). this is one of the reasons (if not the main reason) why gromacs are processed that much faster than the other wu's. just an added point for reference- the GAH wu's (fahcore_ca.exe) don't use assembly code optimizations either.
rock on! fold on! to the top 100 we shall climb (raaaah!!!)!!!
len444
Postby J.C.GARCIA » Wed Oct 29, 2003 3:21 pm
well i'm only getting tinkers at the moment . if i were to upload a finished wu , and before i download the next one i disconnected from the internet thus not receiving , would it connect to another server and maybe download a gromac on my next reconnection :?:
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
J.C.GARCIA
Postby len444 » Wed Oct 29, 2003 4:00 pm
J.C.GARCIA wrote:well i'm only getting tinkers at the moment . if i were to upload a finished wu , and before i download the next one i disconnected from the internet thus not receiving , would it connect to another server and maybe download a gromac on my next reconnection :?:
the pause configuration should allow the wu to be completed, sent in, and stopped. i haven't tried it, but this is something to try and verify. you might be able to get gromacs by deleting the fahcore_65.exe (after the completed tinker is sent in), make certain to have the -advmethods -forceasm -verbosity 9 flags in place, and then start up the client. pretty sure you're running as a service (if i remember correctly), so i wonder if you need to perform a reboot to get folding going? i haven't run folding as a service yet, so i'm not hands on experienced in that specific regard.
len444
Postby steve6787 » Wed Oct 29, 2003 5:09 pm
p1004_ppg 10c_273
is stability ok?
Seems to be rock solid, this is my 6th WU on the new machine, and it seems to be very stable!
8 GB RAM
Radeon HD 3450
steve6787
Postby len444 » Wed Oct 29, 2003 5:33 pm
p1004_ppg 10c_273
is stability ok?
stability is a good thing, esp. w/ the 10xx series wu's. there been a lot of discussion that they work the cpu's the hardest of all the wu's. seems that they max the cpu's to such an extent, that overclocking becomes a problem w/ them. it's good to hear that things are stable !
just curious, how much L2 cache does the PIII550 have?
len444
