It is currently Thu Sep 20, 2018 10:36 pm
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2, 3
PostPosted: Tue Oct 28, 2003 7:45 pm
Excessive - i say that's hitting em more than once. One PM per active member is okay in my view.
As to that flag, you can do that on the graphical model, and select pause when done.
PostPosted: Tue Oct 28, 2003 7:51 pm
so if i apply the -pause flag , does it finish the wu completely and then sends :?: or does it finish the frame and then sends whatever information it has worked on :?: . bit confused here :?
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
radeon 7000 64mb w/tv out
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
PostPosted: Tue Oct 28, 2003 7:53 pm
It'll stop the client waiting for you to unpause it once it finishes the unit and sends it.
PostPosted: Tue Oct 28, 2003 8:11 pm
:? :? . ok gonna go to sleep . go to work in 6 hours time . i'll try and digest it tomm . although if someone can post an example on say a working wu and what happens when i apply that flag i'll be obliged :wink:
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
