It is currently Wed Apr 24, 2019 2:11 am
Post new topic Reply to topic  [ 19 posts ]  Go to page 1, 2  Next
PostPosted: Thu Oct 16, 2003 2:16 pm
Hi all.
I wanted to try out Folding@Home for a second extra comp I have. I got a PM from Smurf Pimp and so I decided to use my second comp for it.
Here is the thread I used to get started=
http://www.motherboards.org/forums/view ... hp?t=33399
I had a few questions-
When the graphical view of the Molecule keeps changing and at the bottom of the window dialog box, it says WORKING....
The WU Progress says 10/500 (2 percent). This took about 20-30 minutes. Is this a normal rate or is it slow?
I am also behind a firewall but I dont think that has affected anything.
Am I on the right path?
PostPosted: Thu Oct 16, 2003 2:32 pm
10-15 minutes per percent is about a day per WU which is quite good for a 1.4 on a 500-framer. Since it has been able to get a WU it will be able to put the result back. As long as you have put in 33258 for the team number everything is OK.
PostPosted: Thu Oct 16, 2003 2:36 pm
ok cool thx
PostPosted: Thu Oct 16, 2003 3:15 pm
Thanks for joining up!!!
PostPosted: Thu Oct 16, 2003 3:55 pm
Indeed, thanks for joining the team and supporting us. As to the molecule continuousally changing, that's normal - it's just the view changing.
PostPosted: Thu Oct 16, 2003 10:09 pm
ok so lets say that my dad needs to use that pc that is running folding@home.
He rarely goes online but lets say the time comes up when he does.
Is there any way I can pause the folding?
If I close the program while it is folding, will it start back where it left off?
PostPosted: Thu Oct 16, 2003 10:13 pm
You can pause it and it will resume at the same spot, but it can run while you surf. I multitask and even play games some with it running.
PostPosted: Thu Oct 16, 2003 10:14 pm
Just leave folding running - he won't notice the speed difference. As to shutting it down, and it picking up - some work units do, while others either reset, or request a new one when they are cut off halfway though. The best method is to pause folding when you do this, that way nothing is lost.
PostPosted: Thu Oct 16, 2003 10:20 pm
so he wont notice a difference even if I am giving 100% CPU usage dedicated to Folding@Home?
EDIT: ok nm, i just tested it, it works fine while surfing the net, no difference.
Ill leave it running then!
PostPosted: Thu Oct 16, 2003 10:24 pm
Exctly my point. Even playing games you won't see much difference (unless you have onboard/useless video...)
Users browsing this forum: Exabot [Bot] and 1 guest
