It is currently Sat Feb 23, 2019 4:58 am
Post new topic Reply to topic  [ 67 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 7  Next
PostPosted: Fri Sep 19, 2003 2:40 pm
just done it . it doesnt upload just resumes the work on the wu . thanks aussie . i suppose i will have to wait for it to complete . maybe i forgot to mention that i am using the graphical windows 3.24
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
radeon 7000 64mb w/tv out
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
PostPosted: Fri Sep 19, 2003 6:12 pm
$$$$ this isp . who said that microsoft has a monopoly . make that 4 wu's on queue . i will get there eventually . when are they gonna bring down the adsl prices :cry:
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
PostPosted: Fri Sep 19, 2003 8:27 pm
i find dial up to be problematic w/ window 2000. i get some kind of upload errors (wininet), and it stops the process of getting new WU's. wasted a crapload of time screwing w/ windows. there might be some kind of a coding problem- or perhaps it's just a windows sucks kind of thing. i'm going back to linux, as i'm loosing some valuable time.
btw, i'm not using a queue, but trying to run it simply to upload, and fetch new, and have the dial up automatically initiate, and terminate after a set duration. the hope is that it would work w/ o errors, though this is not the case.
also, the UD monitor that is used to queue WU's is set up to run the 3.24 version. this sucks, as the -forceasm flag will only work w/ the first WU worked on, and revert back with the remainder (unless restarted w/ that flag). perhaps one of the UD monitor betas will work w/ the 3.25 beta versions???
PostPosted: Wed Oct 01, 2003 7:47 pm
i have two wu's on queue now for the last three days . i've been folding away happily but it sends the first on the queue and the rest of the two are left strnded on the queue . the log file tells me this .
couldnt send http request to server ( winninet )
could not connect to assignment server 2
is this the fault of their server :?:
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
PostPosted: Wed Oct 01, 2003 10:50 pm
either the server is congested, or your modem settings need to be adjusted. running w/ the -verbosity 9 flag will usually give the server ip address that you're trying to connect w/ and then they at the FAH forums can look into it. you'll need to discuss it w/ them though. FAH forum is here:
http://forum.folding-community.org/index.php
if you use the -queueinfo flag, and then look at the fahlog, it should give a status of your wu's. if they are finished, then try the -send all flag. remove either -queueinfo, or -send all flags when done w/ them, to resume normal crunching.
btw, w/ the linux console, the terminal window stays open, and the queue status is reported there, but w/ windows, it immediately closes the console, and you must look at the fahlog to see what the queue status is.
PostPosted: Thu Oct 02, 2003 7:01 pm
well i managed to uplad without using any flags . must have been the server . thanks for all the info . nice reading :wink: by the way the send all flag , do i remove it before or after downloading the next wu :?:
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
PostPosted: Thu Oct 02, 2003 9:29 pm
the client won't work normally w/ the -send all flag present. it will close the client right after it functions. give it a try sometime, and you'll see that it can't be present for normal crunching. same thing w/ the -queueinfo flag.
PostPosted: Fri Oct 03, 2003 6:52 pm
:wink: k thamks . i'll try it when again i have a couple of wu's queue :wink:
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
PostPosted: Fri Oct 03, 2003 8:07 pm
not sure i'm following- are you using UD monitor to queue wu's? or is this just a matter of having trouble uploading wu's?
btw, you should upgrade to the 3.25beta version. this might have better performance. it'll definitely give you a ~20% speed boost w/ the -forceasm, and -advmethods flags. now the correct procedure to change versions, might involve configuring an ask before send, complete the current wu, then use the -send all flag to upload all completed wu's, and then uninstall the 3.24 version. this will still leave a directory/ folder to which you can add the 3.25beta version (console would be best). then use the guides section at the team page as a reference to completing the install of the newer version.
PostPosted: Fri Oct 03, 2003 8:34 pm
well i'm on dialup and sometimes when i try to upload it cannot connect to the folding server , but i suppose it can be a faulty server or congestted one
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
