2 F@H clients on 1 machine
Postby J.C.GARCIA » Wed Sep 17, 2003 3:26 pm
evasive whats the difference between the tinkers and gromacs :?: . please short and in laymans terms
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
radeon 7000 64mb w/tv out
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
J.C.GARCIA
Postby Tulatin » Wed Sep 17, 2003 3:49 pm
the advmethods increases your chances of getting grommacks - you still will get tinkers. As to the difference, Tinkers are designed in a frame format, usually about 400, while grommacks are written to tuilise the cpu's special features to speed up calcualtions, and consist of steps.
Tulatin
Postby joshvee » Thu Sep 18, 2003 9:20 pm
Just noticed that a hyperthreaded machine running 2 clients counts as 2 processors on the F@H stats and user page :(
joshvee
Postby Tulatin » Thu Sep 18, 2003 9:22 pm
why yes it does. Why is that a bad thing? You could run 4 clients, get work units done ar 1/4 the speed, but have 4 cpus...
Tulatin
Postby len444 » Thu Sep 18, 2003 9:45 pm
joshvee wrote:Just noticed that a hyperthreaded machine running 2 clients counts as 2 processors on the F@H stats and user page :(
each instance running hasn it's own specific id#, which shows as a "processor", but doesn't always have to be a actual processor.
btw, how's the hyperthreaded performance?
len444
Postby J.C.GARCIA » Fri Sep 19, 2003 2:25 pm
Tulatin wrote:the advmethods increases your chances of getting grommacks - you still will get tinkers. As to the difference, Tinkers are designed in a frame format, usually about 400, while grommacks are written to tuilise the cpu's special features to speed up calcualtions, and consist of steps.
tulatin read this
Actually, you don't need the -advmethods flag to "test" gromacs. Gromacs has been released to the general public and you'll be getting a mixture of WUs, right along with everybody else.
Adding the -advmethods flag does give you a preference for the potentially unstable WUs so you'll get a higher percentage of these types of problems. (You'll generally get a higher percentage of Gromacs WUs, too.) It's actually the WU that you're testing, not the fundamental code in the core. Different WUs can have decidedly different results, depending on the characteristics of the particular protein.
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
J.C.GARCIA
Postby Tulatin » Fri Sep 19, 2003 2:35 pm
oh. well - that would explain why a lot of the work units you recieve using advmethods will reset if folding crashes...
Tulatin
Postby J.C.GARCIA » Fri Sep 19, 2003 2:46 pm
the wu's dont reset . it will send them with whatever work has been done on them . but i'm also sure that i'm not the only one in the team using the advmethods command . out of the two pc's which are the same , read sig , the one with the advmethods command does this .
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
J.C.GARCIA
Postby Tulatin » Fri Sep 19, 2003 2:48 pm
really? no wonder my point counter was rising... so essentially when you "lose your work", it just sends whatever it's got and starts again...
Tulatin
Postby J.C.GARCIA » Fri Sep 19, 2003 2:57 pm
it will send whatever work has been done and then it will download the same or another type of wu :wink: . why you've also been getting problems :?:
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
J.C.GARCIA
PreviousNext
