It is currently Sun Oct 21, 2018 6:48 am
Post new topic Reply to topic  [ 101 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11  Next
PostPosted: Sat Oct 25, 2003 11:01 am
I was wondering about active , inactive, total processors, etc, so I went through the list.
Active:
1.Default_Dave Active Proessors within a week>>21
2.Aussie " " >>8
3.len444 " " >>4
4.J.C.Garcia >>2
5.Southwind25 >>3
6.evasive >>2
7.Wolverineman85 >>2
8.sodsm_live >>1
9.gamepyrate >>4
10.MrMozart >>1
11.eric2075 >>1
12.Smurf_pimp >>1
13.whiteboy >>1
14.Ladd >>1
15.Wookie8662 >>4
16.netstoy >>1
17.beeboy >>1
18.Ha1rDa3m0n >>1
19.speedblurr >>1
20.Cortez_The_Killer >>1
21.Gryphyn77 >>1
22.Tulatin >>1
23.Miki >>1
24.Tau >>2
25.YouGiveMeRash!!! >>2
26.ptousig >>2
27.steve6787 >>1
28.dell_m_m >>1
29.liz >>1
30.Hog >>1
31.CAIN505 >>1
Inactive
1.Gryphyn
2.Joshvee
3.Aussie_Dual
4.Aussie_Challenge
5.Wally987
6.Ripshod
7.effika
8.tbird9768
9.ShadowHawk
10.Danny_the_bum
11.joshvee_challenge
12.Kingoflosses
13.PickleHead
14.COPPERSHIRT
15.Cazador
16.len444_
17.CAIN
18.barmouth
19.Mesanna
20.DANNYTHEBUM
21.dark_lord
22.labmann55
23.Krista
24.tarostar
Listed on multilpe teams(not sure of status)
1.Melissa
2.ZeratulsAvenger
So it looks like we have at least 75 active processors in the last week. I have no idea about total MHz's.
PostPosted: Sat Oct 25, 2003 12:06 pm
the active processors in a week isn't an accurate figure for actual processors active! if you reinstall FAH, then it will show as another processor. it generates a unique machine id for each installation, which shows as a processor. it'll stabilize in a week though, and show a more accurate figure
i actually have 2 processors active at this moment (even though it shows 4). i will have another going by next week- it's just dependant on quality if it will happen or not.
PostPosted: Sat Oct 25, 2003 1:34 pm
I've changed from 3.24 to the 3.25 beta on 2 of my 3 machines you suggested Len, and it shows mine right.
PostPosted: Sat Oct 25, 2003 2:45 pm
you must have just replaced/ renamed the the 3.24 w/ the 3.25beta, which as per proof in discussions w/ jc garcia, it won't change the unique machine id#.
PostPosted: Sat Oct 25, 2003 2:58 pm
No I uninstalled the 3.24 from add remove programs and downloaded and installed the 3.25 beta version.
PostPosted: Sat Oct 25, 2003 3:12 pm
console, or graphical? every time i reinstall, it'll generate a new id #, and then will show up as another processor.
3.24graphical is a "full released version", which means it includes an installer/ uninstaller. perhaps removing from add/ remove left the other files behind, whereas using the uninstaller that is provided w/ the 3.24 graphical version will wipe the whole thing out???
3.25beta graphical is not a full released version, so it is just the executable, which is installed via a replacement/ renaming procedure.
PostPosted: Sat Oct 25, 2003 5:48 pm
just like to point out that yes i am running the 3.25 like len says in his procedure . but i would also like to point out that my son uses the 3.24 graphical , the two pc's are exactly the same specs and we do the same wu's in exactly the same time per frame , so to tell you the truth i am not getting any speed boost with the 3.25 . perhaps this speed boost only applies to athlons :?:
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
radeon 7000 64mb w/tv out
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
PostPosted: Sat Oct 25, 2003 6:36 pm
this is probably because you are stopping and restarting folding daily, which will reapply -forceasm to the 3.24 version when such occurs. you were speaking about dial- up having an ask before send setting- perhaps restarting folding reapplies -forceasm. if you would run folding automated, so that it requires no intervention, then the 3.24 will drop the -forceasm flag after the 1st wu is completed. only reapplies it after a restart, which then becomes wu#1 in that context.
PostPosted: Sat Oct 25, 2003 6:41 pm
hmm , well i'm not restarting anyway only occassionaly
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
PostPosted: Sat Oct 25, 2003 6:56 pm
Ok Len we may be talking about different things. It did reset to 0 WU's on my graphical display. On one machine it went from 66 to 0 and started over. I'm taling about in the team stats it still shows me only running 3 processors which is correct. I changed them on Tuesday , so the change was in the last week.
