Our total amount of Ghz
Postby Tulatin » Sat Oct 18, 2003 6:14 pm
-config is for the console only - it does exactly what it says.
-local essentially tells folding to stay in it's folder, rather than look about for work.
Tulatin
Postby Southwind25 » Sat Oct 18, 2003 6:38 pm
I just downloaded the first work unit on a Barton 2500 that's running at 2100 MHz. I'm going to tweak it later, but wanted to get it folding. That brings my and my son's (ShadowHawk˜) total to something slightly over 7200 MHz's.
Southwind25
Postby J.C.GARCIA » Sat Oct 18, 2003 6:45 pm
so the -local flag will enable it to work and send but not recieve a wu , correct :?:
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
radeon 7000 64mb w/tv out
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
J.C.GARCIA
Postby Wookie8662 » Sun Oct 19, 2003 1:01 am
The -local flag tells the client to look for the config file in the directory it is in, instead of looking in the registry for the config.
I am trying to setup a duallie system, and I need the -local flag, so I can run 2 clients at the same time. If you are running a single CPU board, you dont need to use the -local flag.
Wookie8662
Postby len444 » Sun Oct 19, 2003 9:14 am
don't use the -local flag w/ the graphical client (as per wookie's explanation). i think i've seen people at the FAH forums who have used it, and were having problems.
the one thing i'm not sure about is the windows console installed into a "directory"/ folder at say my desktop, and a shortcut to it is placed at the desktop as well. it's a local directory, outside of the registry/ and programs directories, so the local switch would seem to be needed. i did use it while testing the 3.25beta console, and didn't find a problem w/ it (unless there were, and i'm not aware of it). i wonder if it would interfere w/ a modem configuration?
len444
Postby Tulatin » Sun Oct 19, 2003 12:25 pm
Surprisingly, i turned off -local, and it did help a little - my WU didn't reset when i paused and shut it off...
Tulatin
Postby Wookie8662 » Sun Oct 19, 2003 9:25 pm
Got the duallie (XP1600's) up and running 2 clients now.
I think the key was the affinity setting, to "force" one CPU to each client.
Add those CPU's back into the total
That brings me up to 5 CPU's folding, all running the 3.25 console.
XP1600
XP1600
XP1600
XP1700
XP2000
Oh, and I have 2 XP1900's on the way to upgrade the duallie.
Now to look for another dual CPU board. :wink:
Wookie8662
Postby Tulatin » Sun Oct 19, 2003 9:40 pm
Ooh, another farmer. This is uber-good. We're sure to pull ahead of PC-Mech now.
Tulatin
Postby Wookie8662 » Sat Oct 25, 2003 1:12 am
It lives!
I added a second power cable to my duallie motherboard using a leftover 4pin molex plug. It is soldered to the ATX pins on the backside of the MB.
I've seen a few instances of people melting thier ATX connector and plug on this board (2460 v1.00), so I decided to do some surgery.
I removed the 2 XP1600's and dropped in a pair of XP1900's that have the L5 bridges intact.
So theres another bump in Mhz for each CPU there.
Who is keeping track of the total in this thread anyhow? :roll:
Another system on the workbench getting assembled as we speak.
Once a farmer, always a farmer I guess.
Wookie8662
Postby Southwind25 » Sat Oct 25, 2003 1:16 am
We probably need to do a recount. Have some new folders and have lost some.
Southwind25
PreviousNext
Users browsing this forum: Istellabot [Crawler] and 2 guests
