Don't log off!!!
Postby Tulatin » Mon Sep 01, 2003 4:44 pm
Hmm. It may be that the client "loses" the files under a NTFS system...
Tulatin
Postby evasive » Mon Sep 01, 2003 6:24 pm
It may also be you need to wait for 20 seconds or so before checking the status. The first period it will show 0/0 then it shows where it left off. On my machines it does. One XP Pro, one server 2003.
Note: OpenGL in server 2003 still sucks. Wait for SP1 to fix that I think...
Postby Tulatin » Mon Sep 01, 2003 6:25 pm
I have the same thing with the 0/0 when it first starts up. Then aftera while it gets back to 335/400.
Tulatin
Postby J.C.GARCIA » Mon Sep 01, 2003 6:42 pm
same thing happens here
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
radeon 7000 64mb w/tv out
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
J.C.GARCIA
Postby Tulatin » Mon Sep 01, 2003 6:44 pm
IT's a good thing to know that that's normal.
Tulatin
Postby Ripshod » Mon Sep 01, 2003 7:32 pm
No. At startup mine downloaded a new WU and lost the work I had put in. Now running version 3.25 with no problems.
Ripshod
Postby Tulatin » Mon Sep 01, 2003 7:35 pm
I suppose this is one of those things that has mixed results no?
Tulatin
Postby Ripshod » Tue Sep 02, 2003 3:02 am
No,don't worry, I'm still fully into this and it would appear that the BETA is in better shape than 3.24. Now I'm running smoothly, no probs.
Ripshod
Postby Ripshod » Tue Sep 02, 2003 3:04 am
And if you do download version 3.25 I reccomend downloading both the graphical AND the console version. Install them both in the same folder and you can switch between them at will!!
Ripshod
Postby DefaultDave » Tue Sep 02, 2003 3:08 pm
i know what you mean ripshod, i've lost a few WU's (guess we all have). esp inthe beginning of all this when i was learning the best way to get it done. (all on XP pro ntfs)
recently i had a weird problem on my dial up boxes (my home pc's) the graphic client got to 20% and poped up the "ready to connect to network" 8O . so i did...and it downloaded new work to work on...loosing the 20% it already cranked out. hmmm.... (3.25)
then the console blow up right after it (3.25 as well) saying it was ready to connect to netowork after like 9-10 steps. so i lost that one as well. all is running perfect after that lil hiccup though.
got a question too...i used to see the "frame 01...02...03...ect" in the console version...now i get the Step 01 "writing to hd" (or whatever it says) with the 100 out of 400 and so on ... no more frame references.
what's the deal? is this from the -advmethods or -forceasm ? or is it cuase of the -local switch? just curious...all's running.
DefaultDave
PreviousNext
