It is currently Wed Sep 19, 2018 11:17 pm
Post new topic Reply to topic  [ 60 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Mon Sep 01, 2003 1:39 pm
Ah, you must be using the BETA. Downloaded it but I want to complete this WU before I install it.
PostPosted: Mon Sep 01, 2003 1:43 pm
I don't think windows are responsible for that problem. I installed the client software on Win2000 and winxp and I experience no such problems. Actually I shut down on of my system for more than 2 days and when I reboot the software continues right where it left off.
You need to investigate the problem on some other angle. Once again it neither win xp nor 2000.
Help humanity .....join the
Motherboards.org
folding team! 33258
PostPosted: Mon Sep 01, 2003 1:46 pm
I agree with miki02131
PostPosted: Mon Sep 01, 2003 1:49 pm
Tulatin, are you using the console version, or graphical?
PostPosted: Mon Sep 01, 2003 1:52 pm
Ripshod wrote:
Using client version 3.24, the only option I've got is to 'Pause Work', which I do. It doesn't matter to me that much now cos I'm folding 24/7 from today, just thought I'd bring it up for the unaware.
actually select 'pause work' first, then select 'quit'.
PostPosted: Mon Sep 01, 2003 2:00 pm
Yeah, that's what I do. I've thrown in the towel with version 3.24. The BETA is running, if there's any problems I'll post again.
PostPosted: Mon Sep 01, 2003 2:09 pm
i'm also using the graphical version3.24 and i just pause work , shut down and it carries on where it left . using xp home
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
radeon 7000 64mb w/tv out
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
PostPosted: Mon Sep 01, 2003 2:19 pm
Ahha, I'm running XP Pro. Could this be it?
PostPosted: Mon Sep 01, 2003 3:51 pm
what file system are you using?
PostPosted: Mon Sep 01, 2003 4:41 pm
i use fat32
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
