It is currently Sun Mar 24, 2019 11:59 pm
Post new topic Reply to topic  [ 96 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9, 10  Next
PostPosted: Tue Aug 19, 2003 10:12 pm
thanks a lot man, its good to know i didnt just do this for nothing
btw, have you joined the F@H team yet?
PostPosted: Tue Aug 19, 2003 10:18 pm
Yeah, I joined. I don't know much about all this but I'm using the screensaver version. I'm on a size 5,000 job right now. I thought the biggest they got was 400.
AMD XP1700+
MSI K7N2-L
1 512 stick of PC3000
2 512 sticks of PC3200
Spire FalconRock2 HSF
Windows XP
Antec SLK3700AMB w/350w psu
PostPosted: Tue Aug 19, 2003 10:20 pm
Sorry, I think it's actually a 2,500.
AMD XP1700+
MSI K7N2-L
Windows XP
PostPosted: Tue Aug 19, 2003 10:21 pm
sometimes is says a larger number than it really is. look at the number of the WU and match it up with the one on here http://folding.stanford.edu/psummary.html
chances are it will jump at incriments of 50 frames, so 5000 divided by 50 = a 100 frame WU
PostPosted: Tue Aug 19, 2003 10:41 pm
the same applies to a 2500 - it steps up by 25 at a time, so it's just a 100. Usually, if you see above 400, it's just a 100-framer in disguise
PostPosted: Tue Aug 19, 2003 10:43 pm
i just added that to the FAQ since its a really common question
PostPosted: Tue Aug 19, 2003 10:58 pm
Hey people you probably already realize this but I'll post it anyway as I haven't seen anyone mention it.....
If your comp isnt doing anything and you don't plan to use it, (other than just folding) press Ctrl/Alt/Delete, click the processes tab, find the FahCore_65.EXE, highlite it, right mouse click, highlite "set Priority" and set it to normal or BelowNormal......it runs faster....but be sure to set it back to Low if you want to do anything on ur comp.... :)
PostPosted: Tue Aug 19, 2003 11:01 pm
i tried that b4 but i didnt find it made a difference, i once put it up to realtime but that froze my system. what does putting it on realtime do???
ps fah core 68 hahahaha, u got stuck with a tinker!!!!!
PostPosted: Tue Aug 19, 2003 11:09 pm
hehe it may be a tinker but its worth 70 points :P Hang on its 65 not 68...but its still a tinker
Yea I tried realtime to and it froze mine also. But mine does seem to run faster when I increase the priority....maybe coz I have allot of background programs running
PostPosted: Tue Aug 19, 2003 11:26 pm
Real time = FULL resource use. DO NOT USE unless spare processor avail, cause the one it's on will ahve no cycles left. Use setting below this for decicated machines.
