It is currently Wed Sep 19, 2018 7:07 am
Post new topic Reply to topic  [ 96 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 10  Next
PostPosted: Tue Aug 19, 2003 4:28 pm
you mean like this? Thats all i could fit cause i have too much bb code in it
PostPosted: Tue Aug 19, 2003 4:57 pm
i think new Team Page! might be better. this will differentiate it from the one in my sig (which is just an outline of sorts for reference purposes), and make it look more official.
btw, i tried your short cut trick- i'm thinking it's relevant to the graphical client. i still should be able to enter the command in the command prompt window, which is what i want to know how to do.
PostPosted: Tue Aug 19, 2003 5:02 pm
thats how the people at the FAH forum told me how to do it and it works for me, after the second quoteation mark put a space then a "-" and put the command. then click on the short cut
i dont think you can enter any in the ms-dos prompt
PostPosted: Tue Aug 19, 2003 5:21 pm
guys my sons P3 500 just finished a 500 framer and downlaoded the next WU. What does it mean when it says the next WU is 2500 frames? I know tulatin has had some experience with this. Is it faulty? Should I cancel it? or let it keep working on it....Might be a good question for the FAQ section.
PostPosted: Tue Aug 19, 2003 5:23 pm
its normal. you will notice it jump at 25 frame incriments. 2500, divided by 25 = a 100 framer. same with one u get that sats 500, they jump 5 frames at a time making them 100's too
if ur not sure about one check http://folding.stanford.edu/psummary.html and see what size it really is
PostPosted: Tue Aug 19, 2003 5:31 pm
i see what your talking about now. so input all the flags, and have seperate machine id #'s for each folder instance (and different labels for each folder) of the executeable. then it's just a matter of double clicking each short cut to the executable to engage each instance.
last thing left is the configuration of task manager for each instance in a multi cpu config.?
PostPosted: Tue Aug 19, 2003 5:32 pm
i'll leave that one up to you lol
PostPosted: Tue Aug 19, 2003 5:33 pm
ok thanks smurf
PostPosted: Tue Aug 19, 2003 5:47 pm
OK how about in a standard comp (none dual cpu and none hyperthreading) say an AMD or P3 or P4 533/400 ....can u run dual instances of the program?
PostPosted: Tue Aug 19, 2003 5:49 pm
i'd say you probably could......but i'm not sure, it would be pointless though because each would use 50%
