Folding at Home?
Postby Tulatin » Tue Aug 12, 2003 6:59 pm
If you want to OC it, get a pair of Sk6 sinks, and 1 120 mm fan to cool both. As to the linux aspect, ask len about it - he's got it working.
Tulatin
Postby evasive » Tue Aug 12, 2003 7:00 pm
command-line version in windows should be about as fast as the linux variant. No dual-CPU though.
Postby Tulatin » Tue Aug 12, 2003 7:00 pm
Oddly enough, i found the graphical model to be faster than the command line one when it's minimized to the task bar icon.
Tulatin
Postby Tramp » Tue Aug 12, 2003 7:10 pm
Nascar .... one of your fellow PCA posters does two Folding @ home teams user name wvjohn
you could prolly do the same thing with ours
Tramp
Postby Tramp » Tue Aug 12, 2003 7:13 pm
is there a plan to do a dual processor ... variant?
otherwise Ill just have to put bout 80 486 thru Pentium3's together and get a whole buttload of processors active
I might run out of hdd tho I think i only got bout 20 or so
Tramp
Postby Tulatin » Tue Aug 12, 2003 7:15 pm
What do you mean by that dude? and if you can - ASSEMBLE SYSTEMS LIKE MAD, AND USED CD BASED LINUXES TO RUN FAH!
Tulatin
Postby Tramp » Tue Aug 12, 2003 7:26 pm
that would work wouldn't it!!
No HD either just active processing power
Ne 1 have a multiplexer for monitor keyboard mouse and bunches of cabling
Is there a way to set up machines to use the same power source like a rack mount something or other ... just slide the MOB's in slots???
I got bout same abount of CD drives and PSU as I got MB ... the only problem Is that I'm sure unless i figure out a way to distribute power I'm going to have one hell of an energy bill! No Way I' pluging in 30+ PSUs it would fricken fry my breakers for sure! 8O 8O
I'll see if I can get a couple of the faster ones up and running tonight when i get home
WAIT stop everything ... put on the brakes ... I just got 4 ports on my router. Could i network a bunch of them together and then go to the router from just one of the machines?
Tramp
Postby evasive » Tue Aug 12, 2003 7:29 pm
Setup a 486 as NAT router...
Postby Tramp » Tue Aug 12, 2003 7:40 pm
the processors are slot 1 need different cooling options
the Sk6 sinks wont work for that processor type
Tramp
Postby Tulatin » Tue Aug 12, 2003 7:42 pm
Pop off the plasitc shells, have a 120 mm fan blowing down into the region. As to the power, just use a LOT of surge bars.
Tulatin
PreviousNext
