It is currently Thu Jul 02, 2020 9:45 am
PostPosted: Fri Jun 15, 2018 12:25 am
:o The F@H GPU has stopped folding.
How do I fix this?
I haven't changed my PC recently. This problem just started today.
PostPosted: Fri Jun 15, 2018 4:31 am
Check the console, see if the program is 'paused' for some reason. Latest client for the F@H process? Maybe the Stanford servers are down, possibly "full" registers. You can check if your server is on line or not.. http://fah-web.stanford.edu/pybeta/serverstat.html
Maybe some help here.. https://foldingforum.org/search.php?key ... ed+folding
PostPosted: Fri Jun 15, 2018 9:11 am
:( I have no clue about what I need to be looking for.
I tried reinstalling F@H, but the problem is still there. A while back I had another issue with F@H. It seems a Nvidia driver update caused/fixed the problem.
So I tried updating my driver, but the problem is still there. :(
________________________________________________________________________________________________________________________________________________
I tried reinstalling F@H again. This time the problem was fixed. I needed a newer version of F@H.
PostPosted: Sat Jun 16, 2018 8:19 am
Good news.
With video drivers, sometimes a 'newer' version has negative issues that older versions did not have.
Had similar problems when I was doing the F@H. The nVidia driver sometimes stopped responding with my GTX460 card. Was latest version, but had issues. Rolled back to a previously known-good version, then OK.
PostPosted: Fri Apr 03, 2020 7:20 am
When I faced this problem, the programme was paused.
https://eleggible.com/roman-numeral-converter/
