It is currently Tue Aug 14, 2018 7:59 am
 Post subject: cpu work units...
PostPosted: Wed Nov 02, 2016 7:10 am
are there any cpu work units to download anymore? 'cause no machine I have folding on does them anymore. it's all about the gpu, and that's all that gets dl'ed, as far as I know.
what's going on?
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
 Post subject: Re: cpu work units...
PostPosted: Wed Nov 02, 2016 3:22 pm
I still get CPU work units. Perhaps your client version is not up to date?
Had to go with Win 7 OS version, a few years ago.. as Win XP was no longer compatible.
Did an upgrade to Win 10, but reverted back to Win 7. Too much 'crapaloogah' with Win 10!
Check the "Requirements" in this link..
https://folding.stanford.edu/home/guide ... all-guide/
My F@H setup, semi-dedicated..
Case: Generic 5-bay full tower.
Mobo: Intel D975XBX2KR I975X LGA775.
CPU: Intel Core 2 Duo 2.4 GHz, (SL9S8) 1066 FSB speed.
CPU cooler: Dynatron K987.
Memory: G Skill 2 GB, GSK F2-8500CL5D-2GBPK 1066 Timing 5-5-5-15.
Video: Nvidia-EVGA GTX460 PCI-E x 16, 1 GB.
Audio: SigmaTel STAC9271D 8-channel.
PSU: Antec 650 watt (EA-650).
Hard drive: Seagate ES ST500NM0011 500GB 7200 RPM SATA.
Optical: Sony DVD R/W 540A and Pioneer DVD R/W 116D.
OS: Win 7 Home Premium
PostPosted: Fri Nov 04, 2016 5:44 am
using version 7.4.4
my main rig...
asrock 970 extreme3
antec neo he 650r
PostPosted: Sat Nov 05, 2016 6:20 am
You can easily check on the F@H status by right-clicking the icon in the SysTray box, then choose 'advanced control'. A panel will show if there is CPU plus GPU activity, and the progress.
Recommended by Stanford to use the provided screen saver for minimal background activity while the GPU folding is active.
