It is currently Tue Aug 04, 2020 8:03 pm
Post new topic Reply to topic  [ 13 posts ]  Go to page Previous  1, 2
PostPosted: Mon Dec 23, 2013 2:13 pm
Thanks for the info Boheemee! So far things seem to be working fine...I've already completed 2 WU for over 10K points with no problems.
Would there be any reason or advantage to install the newer version of the [email protected] program? I tend to leave well enough alone, but of course if the newer program works faster (as in more points!) then I will do that.
Hope you have a good Christmas as well :)
Ted
PostPosted: Mon Dec 23, 2013 6:41 pm
I don't know that there is any advantage to running the newest version of [email protected] software. Like you I tend to leave well enough alone,(if it ain't broke don't fix it) The link below is to the V7: Introduction page. You can read the info and decide for yourself. I may try it at some time in the future, but I'm satisfied with the version I'm running for now.
http://folding.stanford.edu/home/faq/fa ... roduction/
PostPosted: Tue Dec 24, 2013 6:52 am
my points totals rocketed up once I started using v7... it uses the graphics card as well as multi-threads the processor really well.
thumbs up!
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
