It is currently Sat Jul 04, 2020 12:29 am
 Post subject: Avatar help
PostPosted: Sun Jun 21, 2009 12:06 pm
This is the one I am trying to use, it does not work, did these change?
Sorry, I haven't been on the forum for a while.
http://www.motherboards.org/avatar/inte ... avatar.jpg
SOME THINGS MUST BE BELIEVED TO BE SEEN
MEMBER- MOTHERBOARDS.ORG FOLDING TEAM
>>>>>>>>>1,000,000 POINTS<<<<<<<<<
PostPosted: Sun Jun 21, 2009 2:34 pm
I guess those Avatars for the CPU type/F@H points are no longer in use. Did a browse through the profile pages of Avatars, but none found. You could always make up your own, as long as it meets the size allowed, and upload it to the Forum. Or use a hosting service, and link to it.
I have collected more than 1,400 Avatars and icons. A bit over 7 megs!
PostPosted: Mon Jun 22, 2009 2:09 am
Thanks.
Sad to see things change after an absence. :-|
My contributions keep coming though.
Nearing a HUGE milestone and plan to keep going as long as possible.
:D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
PostPosted: Tue Jun 23, 2009 3:15 pm
Yes, things do change.. sometimes for the better, sometimes 'just because'.
I see you are in the "Top 20" as the F@H ranks go. Great work! I am down quite a bit from you, but still chugging two WUs on my system. Just cracked the 150,000 mark! But all contributions help in the quest to find how and why proteins 'fold' as they do.
