FahCore_a1.exe being caught as a Trojan Horse???
Post Reply
MrG
Post by MrG »
I've been getting alerts from my anti-virus (AVast) all day that FahCore_a1.exe is a Trojan Horse :?
Folding fails to run even if I choose to ignore the warning from AVast. So I've not been able to Fold all day! :x
Has anyone else seen this? Can anyone offer any useful advice to solve the issue?
Post by Karlsweldt »
Doesn't sound good!
May be best to shut down the [email protected] process in that folder, and move the core to another folder (Temp?). Then restart the WU process, and if the core it needs is not found, a new one will be downloaded automatically.
Viral types look for executable files to start ravaging.. with the "bat", "com" or "exe" tagnames.
Here is some info on the [email protected] core types.
This page link may be of use. It explains how to check the integrity of executable files with 'hash marks'.
MrG
Post by MrG »
AVast sorted the "false positive" problem with a database update.
I'm just curious if it's ever happened to anyone else before?
A whole day wasted! :x :x :x
Pette Broad
Post by Pette Broad »
I've had plenty of false positives with Avast. They've always been with the data files that [email protected] creates, never with the Folding Core though.
Pete
[img]http://tinyurl.com/3x7anjn/.gif[/img]
paolari
Post by paolari »
How do you get rid of trojan horses without downloading a program? Can you do a system restore to restore it to it's original state(before you started using the computer)?I really need some help because I have a computer that has 13 on it and I don't want to buy a new one. What happens if the trojan horse is unhealable?
Welcome to Motherboards.org, paolari.
The only sure way to cleanse a system that is not in critical stages is by using the 'safe' mode of operation. Disable the Windows Restore feature first, then manually run the anti-virus and other programs needed to flush them out. In 'safe' mode, many programs aren't in an active state.. and this includes most viral and Trojan types. Do a few restarts in 'normal' mode, and once you are sure the system is sanitized, then turn on the Windows restore feature again. If you don't follow this course, then Windows will faithfully undo all your work on the next reboot!
There are many great programs to cleanse a system, and the purchased versions are usually more powerful than those free offers. Additionally, AdAware from www.lavasoft.com/ is great for rooting out nasties and other malicious files and cookies. Another great program is HijackThis from www.majorgeeks.com/download3155.html . Both are freeware, if wanted.
But be cautious about using HijackThis, as Registry 'fixes' are permanent, and may cause system instability if not used properly. If you have questions about a HijackThis scan, post them in our Virus/Spyware topic folder.
Post Reply
