It is currently Sun Aug 19, 2018 8:09 am
PostPosted: Tue Feb 10, 2009 7:53 am
...having a hard time sending finished work units back, or getting new ones this morning. is this normal???
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
PostPosted: Tue Feb 10, 2009 1:37 pm
ok, so they all just scored for me at one time, so i guess whatever it was is over.
my main rig...
asrock 970 extreme3
antec neo he 650r
PostPosted: Fri Feb 13, 2009 3:07 pm
The AS Server failed apparently.
Pete
PostPosted: Mon Mar 09, 2009 5:15 pm
I have 2 PCs, both w/2 finished units and they never send in the results. Been that way for a few days now.
Phenom II X6 1055T @ 2.8GHz
Dual Boot Win7x64/Bodhi
8 GB RAM
Radeon HD 3450
60GB Vertex 2 SSD (For OS's)/750GB for Data
PostPosted: Tue Mar 10, 2009 11:53 am
Are they Double Gromacs? The server they came from has failed and needs repairing. I also have a unit waiting to be returned.
Pete
PostPosted: Tue Mar 10, 2009 12:28 pm
Pete
The one on my main rig is p4452_Seq48_Amber03 GROMACS core
Its also got one in the queue that has been trying to send since Feb.23...
The one on my other rig usually just gets Amber cores which is what its working on right now. But it also has one sitting in the queue....
8 GB RAM
Radeon HD 3450
PostPosted: Tue Mar 10, 2009 1:57 pm
Keep those WUs in the queue. As soon as your assigned server is back on line, they will be accepted. Might be worth a close of the program and restart each morning, if you are running 24/7. The F@H program has log files (plain text) that note your start/finish date, and you should get full credit when submitted. Had some WUs languish for several days, then accepted. I do not run 24/7. Electricity costs more than $0.175 per KWH (USD) by me!
PostPosted: Tue Mar 10, 2009 6:29 pm
Karlsweldt wrote:
I do not run 24/7.
Nor do I, shutdown every night, restart in the morning.
8 GB RAM
Radeon HD 3450
PostPosted: Sat Mar 14, 2009 4:58 pm
Most of the servers are now working O.K again.
Pete
