How to force a WU to be submitted
Postby Ryn » Tue May 06, 2008 10:11 am
Hi guys! I'm having problems with some of my machines as some of the WU's that they have finished haven't been submitted for probably a week or two now. IIRC, there is a procedure on doing this, hope you guys can help out.
BTW, I'm using a console version
Thanks!
Ryn
Postby Karlsweldt » Tue May 06, 2008 12:39 pm
Here is a link to the Console commands.. http://folding.stanford.edu/console-userguide.html
You would activate the console with a command, and add the flag -send all (ex: FAH504-console -send all) to get the queue units sent. But if the server is down or not in use, then you may have to contact Stanford about submission. Normally, an alternate server will accept older WUs. Hope they have not expired!
This is the primary site link for status.. http://folding.stanford.edu/English/Stats . At the bottom, there is an active 'server status' link.. to check on your server's ID status.
And don't forget to check your Firewall status for the port used, to ensure that the F@H process has full access.
