Question about User ID
Postby ThEvil0nE » Fri May 02, 2008 6:32 pm
I just built another new x2 rig and installed 2 instances of F@H. Do you have to use the same F@H User ID number on all your installs?
Thanx
Image Image
ThEvil0nE
Postby evasive » Sat May 03, 2008 6:33 am
Between two different rigs, what do you do?
http://folding.stanford.edu/English/FAQ-SMP
Postby Karlsweldt » Sat May 03, 2008 6:35 am
Only your user name and team # should be the same. Stanford will assign a unique 'serial number' or 'User ID' number to each machine. If you have one process running, then a 'machine ID 1' would be noted.. and if more than one process, then 'machine ID 2' and so on would be added for each.
Postby ThEvil0nE » Sat May 03, 2008 10:20 am
thanx guys 8)
btw... can you install SMP even if you have not set an administrator password on your machine?
Image Image
ThEvil0nE
Postby whiteboy » Sat May 03, 2008 10:38 am
nope need the paassword. no way around it that i know of...but if somebody does it will be nice of them to post it....
4 gigs ram
2 250 gig samsung sata HDs
2 lite on sata dvd burners
whiteboy
Postby Karlsweldt » Sun May 04, 2008 6:12 am
May be some help here in this MS FAQ. But SMP is a basic process that can run without the Administrator account.. as long as it isn't a process that would "hog" the resources.
If the original install of the OS has been done correctly, you need not sign on with a password or user name. The OS assumes any log-on is by the Administrator. That option is given before the OS is completely installed.
You could also run a process by associating the "run as" with the program.. details:.
