WU points
WU points
Postby whiteboy » Sun Feb 24, 2008 1:58 pm
Running SMP on My girlfriends laptop (amd 64 x2) and is running fine. according to FAHmon it will finish a WU in just about a hour under preferred deadline. But she will use the laptop which will slow it down some so the question is; are points issued for having it done before the preferred deadline or the final deadline which gives me an extra day.
4 gigs ram
2 250 gig samsung sata HDs
2 lite on sata dvd burners
whiteboy
Postby Daft Ada » Sun Feb 24, 2008 2:27 pm
You'll get full points for getting done before the preferred deadline, some points for getting it done before the final deadline and no points after the final deadline.
Daft Ada
Postby whiteboy » Sun Feb 24, 2008 4:23 pm
How does it calculate after the deadline. yeah 1760 before the preferred is nice but i'll still settle for half of that before ending.
4 gigs ram
whiteboy
Postby Pette Broad » Mon Feb 25, 2008 7:46 am
There's no difference in points between the prefered and final deadline. So you'll get your 1760 points as long as you send it in under 96 hours. What happens is this, if your WU is not returned within the prefered deadline then the WU gets sent out to another machine and that machine will also get the full points on completion.
Pete
Pette Broad
