setting up a GPU
Postby whiteboy » Mon Feb 25, 2008 8:17 am
Got the latest directx from microsoft ( plus I play Crysis so I now they are up to date). And unless the console version expired since friday(2-22-08) then it should be latest. I do know that the GUI version expired on 2-2-08
4 gigs ram
2 250 gig samsung sata HDs
2 lite on sata dvd burners
whiteboy
Postby Pette Broad » Mon Feb 25, 2008 9:24 am
Running Vista? If so then that's your problem. Latest GPU version doesn't work under Vista. There is a kinda crazy workaround, get hold of previous version of the GPU client and set your system clock back to January :roll: .
Pete
Pette Broad
Postby whiteboy » Mon Feb 25, 2008 10:42 am
settting the clock back? won't that affect the deadlines with my SMP WU's. seems like a lot of trouble just to get 330 points...guess i'll just wait til they support vista
4 gigs ram
whiteboy
Postby Pette Broad » Mon Feb 25, 2008 10:50 am
Yes, best not to mess about with the clock :)
Pete
Pette Broad
Postby whiteboy » Mon Feb 25, 2008 11:12 am
looks like they just update the gpu clients over the weekend. trying them now to see how they work. the console version gives me same error, but the system tray one seems to be trying to get a WU. it did grab one but then said that is was corrupted so its trying again.
4 gigs ram
whiteboy
Postby Pette Broad » Mon Feb 25, 2008 3:48 pm
BTW, I found this affinity setup utility which has been written for Folding@Home.
http://distributed.org.ua/forum/index.p ... topic=1149
Pete
Pette Broad
Postby Karlsweldt » Mon Feb 25, 2008 4:12 pm
Stanford will assign a unique machine "serial number" to each F@H process.. as long as the user name and team are identical. One process would be as "machine #1", the second would be as "machine #2". Your user registration ID# should be identical to both processes.
As to memory usage, an amount of about 1/4 total system memory is adequate.. or about 512 Mb max. Leave "room" for the other identical process and OS needs for basics.
Unsure if it is true, but rumored there is a maximum of eight 'machine ID #s' per operating setup. And this may only be with dual quad-core CPUs active.
Unknown whether there may be some "hints" in the WUs as to malware or viral references, but some anti-virus and Firewall programs may abort or filter out those process items. So a probable cause for corrupted WU sets.
And if you use dial-up Web connections, it is best NOT to use an 'acceleration' program when sending/receiving WUs!!
Set the Firewall to 'fully trust' the server site.
A guide to setting up multiple F@H processes on one system: LINK:
F@H FAQs: http://folding.stanford.edu/English/FAQ-main
Postby whiteboy » Mon Feb 25, 2008 4:18 pm
seems to a bug in the new beta software. browsing thru the forums and found other people are haveing issues with the new beta as well.
4 gigs ram
whiteboy
Postby Karlsweldt » Tue Feb 26, 2008 3:07 pm
Any "beta" version is in the final testing stages before being certified "for all users". Any users of such "beta" versions are normally requested to report unusual responses as well as possibly more desired responses.
Postby Pette Broad » Tue Feb 26, 2008 4:36 pm
An interesting thing I just picked up on is that the GUI client must be set to Machine ID 1 for it to function.
Pete
Pette Broad
PreviousNext
