It is currently Wed Sep 19, 2018 3:21 am
PostPosted: Thu Feb 21, 2008 8:54 pm
Hi everybody seems pretty nice on this forum so I figured you guys wouldn't mind me bugging you with a few new to folding questions. I just installed 5.03 earlier this afternoon and my Anthlon X2 6400 at 3.2ghz is only running @ 50% in Everest. My question is that my comp has only done 180/1500 after being on all day today; Is this good progress or do I need to tweek my setup?
My Username is FLuX43:
and this is what I get when I go to the website
FLuX43 Last updated: Thu Feb 21 20:00:00 PST 2008
Fri Feb 22 04:00:00 UTC 2008
Date of last work unit None
Total score 0
Overall rank (if points are combined) 923311 of 923311
Active processors (within 50 days) 0
Active processors (within 7 days) 0
PostPosted: Fri Feb 22, 2008 12:59 am
First of all, thanks for joining the team, you're very welcome here :) . I'll give you some tips on setting the machine up to maximise the output later today (unless someone else jumps in first). The 50% that Everest is showing means that only one core is running Folding@Home.
Points are only given out when a Work Unit is completed, the stats usually update within a couple of hours. Wu's vary in length, so its quite likely that the one you are working on is worth a lot of points. If you get a chance could you please post your log. Once again welcome onboard. :)
Pete
PostPosted: Fri Feb 22, 2008 7:54 am
:mb_welcome::
PostPosted: Fri Feb 22, 2008 10:59 am
well this logfile is very long so I hope this is the one you wre talking about.
And if its not sorry for wasting your time
--- Opening Log file [February 21 04:34:08]
# Windows Graphical Edition ###################################################
Folding@Home Client Version 5.03
http://folding.stanford.edu
Launch directory: C:\Program Files\Folding@Home
[04:34:26] - Ask before connecting: No
[04:34:26] - User name: FLuX43 (Team 0)
[04:34:26] - User ID: 14B8A8474323156A
[04:34:26] - Machine ID: 1
[04:34:26]
[04:34:26] Work directory not found. Creating...
[04:34:26] Could not open work queue, generating new queue...
[04:34:26] Initialization complete
[04:34:26] + Benchmarking ...
[04:34:29] - Preparing to get new work unit...
[04:34:29] + Attempting to get work packet
[04:34:29] - Connecting to assignment server
[04:34:30] - Successful: assigned to (171.64.122.82).
[04:34:30] + News From Folding@Home: Welcome to Folding@Home
[04:34:30] Loaded queue successfully.
[04:34:33] + Closed connections
[04:34:33]
[04:34:33] + Processing work unit
[04:34:33] Core required: FahCore_81.exe
[04:34:33] Core not found.
[04:34:33] - Core is not present or corrupted.
[04:34:33] - Attempting to download new core...
[04:34:33] + Downloading new core: FahCore_81.exe
[04:34:33] + 10240 bytes downloaded
[04:34:33] + 20480 bytes downloaded
[04:34:33] + 30720 bytes downloaded
[04:34:34] + 40960 bytes downloaded
[04:34:34] + 51200 bytes downloaded
[04:34:34] + 61440 bytes downloaded
[04:34:34] + 71680 bytes downloaded
[04:34:34] + 81920 bytes downloaded
[04:34:34] + 92160 bytes downloaded
[04:34:34] + 102400 bytes downloaded
[04:34:34] + 112640 bytes downloaded
[04:34:34] + 122880 bytes downloaded
[04:34:34] + 133120 bytes downloaded
[04:34:34] + 143360 bytes downloaded
[04:34:34] + 153600 bytes downloaded
[04:34:34] + 163840 bytes downloaded
[04:34:34] + 174080 bytes downloaded
[04:34:34] + 184320 bytes downloaded
[04:34:34] + 194560 bytes downloaded
[04:34:34] + 204800 bytes downloaded
[04:34:34] + 215040 bytes downloaded
[04:34:34] + 225280 bytes downloaded
[04:34:34] + 235520 bytes downloaded
[04:34:34] + 245760 bytes downloaded
[04:34:34] + 256000 bytes downloaded
[04:34:34] + 266240 bytes downloaded
[04:34:34] + 276480 bytes downloaded
[04:34:34] + 286720 bytes downloaded
[04:34:34] + 296960 bytes downloaded
[04:34:34] + 307200 bytes downloaded
[04:34:34] + 317440 bytes downloaded
[04:34:34] + 327680 bytes downloaded
[04:34:34] + 337920 bytes downloaded
[04:34:34] + 348160 bytes downloaded
[04:34:34] + 358400 bytes downloaded
[04:34:34] + 368640 bytes downloaded
[04:34:34] + 378880 bytes downloaded
[04:34:34] + 389120 bytes downloaded
[04:34:34] + 399360 bytes downloaded
[04:34:34] + 409600 bytes downloaded
[04:34:34] + 419840 bytes downloaded
[04:34:34] + 430080 bytes downloaded
[04:34:34] + 440320 bytes downloaded
[04:34:34] + 450560 bytes downloaded
[04:34:34] + 460800 bytes downloaded
[04:34:34] + 471040 bytes downloaded
[04:34:34] + 481280 bytes downloaded
[04:34:34] + 491520 bytes downloaded
[04:34:34] + 501760 bytes downloaded
[04:34:34] + 512000 bytes downloaded
[04:34:34] + 522240 bytes downloaded
[04:34:34] + 532480 bytes downloaded
[04:34:34] + 542720 bytes downloaded
[04:34:34] + 552960 bytes downloaded
[04:34:34] + 563200 bytes downloaded
[04:34:34] + 573440 bytes downloaded
[04:34:34] + 583680 bytes downloaded
[04:34:35] + 593920 bytes downloaded
[04:34:35] + 604160 bytes downloaded
[04:34:35] + 614400 bytes downloaded
[04:34:35] + 624640 bytes downloaded
[04:34:35] + 634880 bytes downloaded
[04:34:35] + 645120 bytes downloaded
[04:34:35] + 655360 bytes downloaded
[04:34:35] + 665600 bytes downloaded
[04:34:35] + 675840 bytes downloaded
[04:34:35] + 686080 bytes downloaded
[04:34:35] + 696320 bytes downloaded
[04:34:35] + 706560 bytes downloaded
[04:34:35] + 716800 bytes downloaded
[04:34:35] + 727040 bytes downloaded
[04:34:35] + 737280 bytes downloaded
[04:34:35] + 747520 bytes downloaded
[04:34:35] + 757760 bytes downloaded
[04:34:35] + 768000 bytes downloaded
[04:34:35] + 778240 bytes downloaded
[04:34:35] + 788480 bytes downloaded
[04:34:35] + 798720 bytes downloaded
[04:34:35] + 808960 bytes downloaded
[04:34:35] + 819200 bytes downloaded
[04:34:35] + 825684 bytes downloaded
[04:34:35] Verifying core Core_81.fah...
[04:34:35] Signature is VALID
[04:34:35]
[04:34:35] Trying to unzip core FahCore_81.exe
[04:34:35] Decompressed FahCore_81.exe (2396160 bytes) successfully
[04:34:35] + Core successfully engaged
[04:34:40]
[04:34:40] + Processing work unit
[04:34:40] Core required: FahCore_81.exe
[04:34:40] Core found.
[04:34:40] Working on Unit 01 [February 21 04:34:40]
[04:34:40] + Working ...
[04:34:40]
[04:34:40] *------------------------------*
[04:34:40] Folding@Home Gromacs Simulated Tempering Core
[04:34:40] Version 1.10 (Oct 4, 2007)
[04:34:40]
[04:34:40] Preparing to commence simulation
[04:34:40] - Looking at optimizations...
[04:34:40] - Created dyn
[04:34:40] - Files status OK
[04:34:41] - Expanded 364248 -> 1799035 (decompressed 493.9 percent)
[04:34:41] - Starting from initial work packet
[04:34:41]
[04:34:41] Project: 3730 (Run 43, Clone 4, Gen 10)
[04:34:41]
[04:34:41] Assembly optimizations on if available.
[04:34:41] Entering M.D.
[04:34:47] Protein: p3730_Seq16_Amber03_Extended
[04:34:47]
[04:34:47] Writing local files
[04:35:31] Extra SSE boost OK.
[04:35:31] Writing local files
[04:35:31] Completed 0 out of 1500000 steps (0)
[04:39:52] Opening http://vspx27.stanford.edu/cgi-bin/main ... e=FLuX43...
[04:40:13] Opening C:\Program Files\Folding@Home\MyFolding.html...
[04:58:24] Writing local files
[04:58:24] Completed 15000 out of 1500000 steps (1)
[05:20:57] Writing local files
[05:20:57] Completed 30000 out of 1500000 steps (2)
--- Opening Log file [February 21 19:45:18]
[19:45:18] - Ask before connecting: No
[19:45:18] - User name: FLuX43 (Team 0)
[19:45:18] - User ID: 14B8A8474323156A
[19:45:18] - Machine ID: 1
[19:45:18]
[19:45:18] Loaded queue successfully.
[19:45:18] Initialization complete
[19:45:18] + Benchmarking ...
[19:45:21]
[19:45:21] + Processing work unit
[19:45:21] Core required: FahCore_81.exe
[19:45:21] Core found.
[19:45:21] Working on Unit 01 [February 21 19:45:21]
[19:45:21] + Working ...
[19:45:23]
[19:45:23] *------------------------------*
[19:45:23] Folding@Home Gromacs Simulated Tempering Core
[19:45:23] Version 1.10 (Oct 4, 2007)
[19:45:23]
[19:45:23] Preparing to commence simulation
[19:45:23] - Ensuring status. Please wait.
[19:45:40] - Looking at optimizations...
[19:45:40] - Working with standard loops on this execution.
[19:45:40] - Previous termination of core was improper.
[19:45:40] - Files status OK
[19:45:40] - Expanded 364248 -> 1799035 (decompressed 493.9 percent)
[19:45:41]
[19:45:41] Project: 3730 (Run 43, Clone 4, Gen 10)
[19:45:41]
[19:45:41] Entering M.D.
[19:46:01] (Starting from checkpoint)
[19:46:01] Protein: p3730_Seq16_Amber03_Extended
[19:46:01]
[19:46:01] Writing local files
[19:46:45] Completed 30000 out of 1500000 steps (2)
[19:51:41] Opening http://vspx27.stanford.edu/cgi-bin/main ... e=FLuX43...
[19:53:51] Opening http://vspx27.stanford.edu/cgi-bin/main ... e=FLuX43...
[19:54:22] Opening http://vspx27.stanford.edu/cgi-bin/main ... um=33258...
[20:35:24] Writing local files
[20:35:24] Completed 45000 out of 1500000 steps (3)
[21:24:00] Writing local files
[21:24:00] Completed 60000 out of 1500000 steps (4)
[22:12:32] Writing local files
[22:12:32] Completed 75000 out of 1500000 steps (5)
[23:01:05] Writing local files
[23:01:05] Completed 90000 out of 1500000 steps (6)
[23:49:41] Writing local files
[23:49:41] Completed 105000 out of 1500000 steps (7)
[00:38:16] Writing local files
[00:38:16] Completed 120000 out of 1500000 steps (8)
[01:26:49] Writing local files
[01:26:49] Completed 135000 out of 1500000 steps (9)
[01:45:21] + Working...
[02:15:23] Writing local files
[02:15:23] Completed 150000 out of 1500000 steps (10)
[03:04:10] Writing local files
[03:04:10] Completed 165000 out of 1500000 steps (11)
[03:53:44] Writing local files
[03:53:44] Completed 180000 out of 1500000 steps (12)
[04:30:15] Opening http://vspx27.stanford.edu/cgi-bin/main ... e=FLuX43...
[04:30:22] Opening http://vspx27.stanford.edu/cgi-bin/main ... e=FLuX43...
[04:42:18] Writing local files
[04:42:18] Completed 195000 out of 1500000 steps (13)
[04:48:33] Opening http://vspx27.stanford.edu/cgi-bin/main ... e=FLuX43...
[05:31:50] Writing local files
[05:31:50] Completed 210000 out of 1500000 steps (14)
[06:20:20] Writing local files
[06:20:20] Completed 225000 out of 1500000 steps (15)
[07:08:51] Writing local files
[07:08:51] Completed 240000 out of 1500000 steps (16)
--- Opening Log file [February 22 18:45:09]
[18:45:09] - Ask before connecting: No
[18:45:09] - User name: FLuX43 (Team 33258)
[18:45:09] - User ID: 14B8A8474323156A
[18:45:09] - Machine ID: 1
[18:45:09]
[18:45:09] Loaded queue successfully.
[18:45:10] Initialization complete
[18:45:10] + Benchmarking ...
[18:45:13]
[18:45:13] + Processing work unit
[18:45:13] Core required: FahCore_81.exe
[18:45:13] Core found.
[18:45:13] Working on Unit 01 [February 22 18:45:13]
[18:45:13] + Working ...
[18:45:14]
[18:45:14] *------------------------------*
[18:45:14] Folding@Home Gromacs Simulated Tempering Core
[18:45:14] Version 1.10 (Oct 4, 2007)
[18:45:14]
[18:45:14] Preparing to commence simulation
[18:45:14] - Looking at optimizations...
[18:45:14] - Files status OK
[18:45:15] - Expanded 364248 -> 1799035 (decompressed 493.9 percent)
[18:45:15]
[18:45:15] Project: 3730 (Run 43, Clone 4, Gen 10)
[18:45:15]
[18:45:16] Assembly optimizations on if available.
[18:45:16] Entering M.D.
[18:45:36] (Starting from checkpoint)
[18:45:36] Protein: p3730_Seq16_Amber03_Extended
[18:45:36]
[18:45:36] Writing local files
[18:46:21] Completed 248829 out of 1500000 steps (17)
[18:46:21] Extra SSE boost OK.
PostPosted: Fri Feb 22, 2008 2:09 pm
That explains why its slow. You have to shut folding down properly or you'll get that message. Use Ctl-C if using the Console, Use quit if you have the graphical. Standard loops means that any boosters like sse or sse2 will not be enabled and that really slows things down.
[18:45:36]
Thats how it should look :)
I'm dog tired from a day of driving but I'll give you some tips in the morning.
Pete
PostPosted: Fri Feb 22, 2008 5:29 pm
A new partner on our folding team is always welcome!
Here is a link for the Console commands.. http://folding.stanford.edu/console-userguide.html
Best to start the program on its first run with the command {typical} [F@H504-console -configonly] and do what is needed. Set all your options, then save. The program will end, then you restart and it will DL all the needed working files and process runs.
If you have 24/7 connection to a Web link, no need to set "ask before connecting" as [no]. Your WUs will automatically be sent.
But if you are using a progress monitor, such as EM iii, that has to be first closed down before the F@H processes are. Otherwise, file corruption will result.. and the WU will probably restart from scratch.
I run two instances of the F@H processes on my P4 Prescott.. each folder is named uniquely, on separate partitions. They are non-service launch features, and I manually launch them from desktop links. Same with the EM iii. That way, if I ever need to, I can totally shut down the services. If launched as a service process, they will never completely shut down.. until the OS terminates the session.. or you use the Task Manager to end the processes.
But no one is immune from those minor glitches on the AC mains. Less than 1/2 second is all the reserve a PSU has.. and the PC may reboot. Other electronic gear may never notice those glitches. A UPS or line-tamer would protect against such infrequent glitches.
PostPosted: Sat Feb 23, 2008 11:55 am
You have 2 choices, the best setup to maximise your points would be The SMP core. For this to work your computer has to have a password, if it doesn't, you need to create one, then using TweakUi (free from Microsoft) you can if you wish set it to Auto log on. However, you do need your computer to be on for 12-16 hours a day as they need to be returned within 4 days. The alternative is to run 2 versions of the Console version. Pretty easy to setup. Just make a new folder, copy the Conslole file into it, create a desktop shortcut and add the flag -local to it then run it. On first running it'll ask for user name, team number and when it reaches Change advanced settings answer yes, then accept te defaults until it reaches Machine ID and set this to 2. You'll also need to add the -local flag to your original console.
Hope this makes sense :)
Pete
