It is currently Mon Sep 24, 2018 1:41 pm
 Post subject: new comp starting
PostPosted: Thu Feb 21, 2008 6:15 pm
Just got done build the new system (Phenom 9500 w/ 4 gigs) after I spend the next 3-4 hours install updates and setting it all up. SMP here i come. Also I got a Graphic card that is supported for the GPU as well so might set that up also. time to crank out some points!!!
4 gigs ram
2 250 gig samsung sata HDs
2 lite on sata dvd burners
PostPosted: Fri Feb 22, 2008 12:51 am
Hey, that's great, that machine should do very well, 2-3k a day maybe :D
Pete
PostPosted: Fri Feb 22, 2008 5:05 am
yeah so far working on WU #2653 for 1760 points. 10 hours 25 minutes running and its already 43% done. so about 24 hours for a WU isn't to bad. I do know that when I get The GPU set up and working it will slow it down some but it should add a nice point increase for it.
Now anybody want to help me set up the GPU for folding? Have a nice card with ATI 1950pro chipset and 512Ram on board. just got to figure out how to set it up anmd get the right drivers it seems.
4 gigs ram
