New Version of FahMon
Postby Pette Broad » Thu Jan 24, 2008 12:15 pm
Version 2.3.2 is now in Beta testing. Follow the download link here....
http://fahmon.net/news/archives/2008/01 ... _51_17.txt
Looks good, has fixed the 3906/3907 bug and isa lot more stable.
Pete
Pette Broad
Postby Myth » Thu Jan 24, 2008 4:04 pm
I know no one here wrote this program but I have a question that someone may have an idea of the answer. Do any of you know how long it might be between beta and final? The version I'm using has some pretty major issues after using it for several days non stop. I don't want to exchange my known set of problems for a new set of issues that may or may not cause issues with other software.
I'd rather just wait for the final version or for the beta to get more refined before I upgrade. VERY much looking forward though.
THANKS for the update post Pete!
Myth
Postby Pette Broad » Thu Jan 24, 2008 5:33 pm
Myth, I've only been running this for about 10 hours and it has cleared up all of the problems I had with it.
#1 Now reports P3906/7 correctly.
#2 Doesn't crash randomly, at least not yet :) . Previous version crashed 5 or 6 times a day (at least) .This one has a 100% crash free record.
#3 Too early to say yet, but I've had a couple of machines that have had their locations changed. So instead of the location being c:\Folding@home, its become "Pette_Broad (33258) or "O.K" or on one occasion entirely blank. I guess this is caused by corruption within the data file when it crashes.
The final version should be out very soon. Just leave the autoupdate feature enabled.
Pete
Pette Broad
Postby Ripshod » Fri Jan 25, 2008 3:45 am
Has issues with the SMP beta client.
Ripshod
Postby Pette Broad » Fri Jan 25, 2008 12:42 pm
Ripshod wrote:Has issues with the SMP beta client.
I've also found that it has major issues with work units that are not in the database. Catastrophic actually as it crashes on loading. I've informed the guy who looks after FahMon.
Pete
EDIT, Someone else had already reported this issue and it has been fixed. No word on when the final version or even a fixed beta will be ready though.
Pette Broad
Postby Daft Ada » Sat Jan 26, 2008 4:38 am
Thanks Pete, the new version does fix all the silliness with these 3906 and 3907 units :D
Daft Ada
Postby Myth » Fri Mar 21, 2008 2:24 pm
There is now 2.3.2a version
http://fahmon.net/download.html
Myth
Postby Karlsweldt » Fri Mar 21, 2008 3:03 pm
Still using the 'old' EMiii version. Will have to see this version is any better.
Postby Pette Broad » Fri Mar 21, 2008 3:31 pm
Karlsweldt wrote:Still using the 'old' EMiii version. Will have to see this version is any better.
EM3 is certainly the most reliable monitor and has the widest range of options too. It won't monitor SMP or GPU work units and it has issues with some of the newer units like those using the DGromacs 2 core. However, it still works well with most units, you just need to edit the protiens file now and then. Unfortunately, it looks like the author has lost interest in it, though with a bit of luck someone else may take it over in the future.
Pete
Pette Broad
