Watch out for P3906 and P3907
Postby Pette Broad » Tue Jan 22, 2008 2:22 am
Yes, FahMon can't read these units properly as they only have 50 frames instead of the usual 100. A fix is due when the next version of FahMon is released.....any day now I believe. So what you have to do is divide the initial FahMon esimate by two.
Pete
BTW, none of the other Folding@Home monitors like EM3 and FahSpy can read these units either.
Pette Broad
Postby Karlsweldt » Tue Jan 22, 2008 2:54 pm
And process steps may become more complicated toward the end of the regimen, taking more time than previous steps. This can throw off the "clock" that monitors the progress.
Postby whiteboy » Tue Jan 22, 2008 3:13 pm
yeah i got two of them running on my desktop now. F@Hmon shows the end time when they reach the 50% mark. GUI interface gives it almost an extra 2 days
4 gigs ram
2 250 gig samsung sata HDs
2 lite on sata dvd burners
whiteboy
Postby whiteboy » Tue Jan 22, 2008 6:07 pm
now this is strange...just had to dur a reboot and now my GUI says that it will copmlete in 5 minutes and its doing a frame at 2.3sec.. i see a bad unit that will get me no points
4 gigs ram
whiteboy
Postby Karlsweldt » Wed Jan 23, 2008 8:14 am
Obviously, a checkpoint became corrupt.. and the process will probably restart from the zero point.
Postby whiteboy » Wed Jan 23, 2008 8:31 am
It ran like that for about 15 minutes, always giving me a different frame time and end time. now it seems to be running fine and looks like it pickd up around where it left off when i did my reboot. checked on it this mornign and it seems to be running like normal. even F@Hmon corrected it self and shows a 1.5 day endtime versus 44 days.
4 gigs ram
whiteboy
Postby Pette Broad » Wed Jan 23, 2008 1:35 pm
Some of these units have frame times all over the place. I had one that folded up to 32 steps at 8mins 30secs per frame. Then it went up to 13 minutes for 3 frames then did a frame at sub 3mins. Later on the frame time ballooned to 32 minutes followed by a 60 second frame :o . After 70 frames it settled back to 8:30 frames,
Pete
Pette Broad
Postby Karlsweldt » Thu Jan 24, 2008 8:50 am
The F@H monitor program doesn't get to read any previous stats as to the process when the program is restarted. Only what is actual. It may take some " warm-up stretches" to get the process down to an organized stepping procedure. Whenever I restart my Console, the noted times of frames is quite different from those of maybe an hour or two later!
Postby Pette Broad » Thu Jan 24, 2008 12:21 pm
Here is part of the actual log. Note frames 35-36, 40-41, 70-71
[18:42:04] Project: 3906 (Run 536, Clone 2, Gen 1)
[18:42:04]
[18:42:04] Assembly optimizations on if available.
[18:42:04] Entering M.D.
[18:42:10] Working on Lig in water
[18:42:10] Completed 0 out of 500000 steps (0)
[18:42:10] Extra SSE2 boost OK
[18:48:10] Timer requesting checkpoint
[18:50:43] Completed 5000 out of 500000 steps (1)
[18:56:43] Timer requesting checkpoint
[18:53:53] Completed 10000 out of 500000 steps (2)
[18:59:53] Timer requesting checkpoint
[19:02:28] Completed 15000 out of 500000 steps (3)
[19:08:28] Timer requesting checkpoint
[19:11:04] Completed 20000 out of 500000 steps (4)
[19:17:04] Timer requesting checkpoint
[19:19:38] Completed 25000 out of 500000 steps (5)
[19:25:38] Timer requesting checkpoint
[19:28:10] Completed 30000 out of 500000 steps (6)
[19:34:10] Timer requesting checkpoint
[19:36:41] Completed 35000 out of 500000 steps (7)
[19:42:41] Timer requesting checkpoint
[19:45:12] Completed 40000 out of 500000 steps (8)
[19:51:12] Timer requesting checkpoint
[19:53:42] Completed 45000 out of 500000 steps (9)
[19:59:42] Timer requesting checkpoint
[20:02:15] Completed 50000 out of 500000 steps (10)
[20:08:15] Timer requesting checkpoint
[20:10:49] Completed 55000 out of 500000 steps (11)
[20:16:49] Timer requesting checkpoint
[20:19:26] Completed 60000 out of 500000 steps (12)
[20:25:26] Timer requesting checkpoint
[20:27:59] Completed 65000 out of 500000 steps (13)
[20:33:59] Timer requesting checkpoint
[20:36:32] Completed 70000 out of 500000 steps (14)
[20:42:32] Timer requesting checkpoint
[20:45:02] Completed 75000 out of 500000 steps (15)
[20:51:02] Timer requesting checkpoint
[20:53:33] Completed 80000 out of 500000 steps (16)
[20:59:33] Timer requesting checkpoint
[21:02:00] Completed 85000 out of 500000 steps (17)
[21:08:00] Timer requesting checkpoint
[21:10:31] Completed 90000 out of 500000 steps (18)
[21:16:31] Timer requesting checkpoint
[21:19:02] Completed 95000 out of 500000 steps (19)
[21:25:02] Timer requesting checkpoint
[21:27:34] Completed 100000 out of 500000 steps (20)
[21:33:34] Timer requesting checkpoint
[21:36:05] Completed 105000 out of 500000 steps (21)
[21:42:05] Timer requesting checkpoint
[21:44:34] Completed 110000 out of 500000 steps (22)
[21:50:34] Timer requesting checkpoint
[21:53:08] Completed 115000 out of 500000 steps (23)
[21:59:09] Timer requesting checkpoint
[22:01:47] Completed 120000 out of 500000 steps (24)
[22:07:47] Timer requesting checkpoint
[22:10:19] Completed 125000 out of 500000 steps (25)
[22:16:19] Timer requesting checkpoint
[22:18:55] Completed 130000 out of 500000 steps (26)
[22:24:55] Timer requesting checkpoint
[22:27:25] Completed 135000 out of 500000 steps (27)
[22:33:25] Timer requesting checkpoint
[22:36:00] Completed 140000 out of 500000 steps (28)
[22:42:01] Timer requesting checkpoint
[22:44:36] Completed 145000 out of 500000 steps (29)
[22:50:37] Timer requesting checkpoint
[22:53:15] Completed 150000 out of 500000 steps (30)
[22:59:15] Timer requesting checkpoint
[23:01:51] Completed 155000 out of 500000 steps (31)
[23:02:57] - Autosending finished units...
[23:02:57] Trying to send all finished work units
[23:02:57] + No unsent completed units remaining.
[23:02:57] - Autosend completed
[23:07:51] Timer requesting checkpoint
[23:10:44] Completed 160000 out of 500000 steps (32)
[23:16:44] Timer requesting checkpoint
[23:22:44] Timer requesting checkpoint
[23:23:36] Completed 165000 out of 500000 steps (33)
[23:29:37] Timer requesting checkpoint
[23:35:37] Timer requesting checkpoint
[23:36:46] Completed 170000 out of 500000 steps (34)
[23:42:47] Timer requesting checkpoint
[23:48:47] Timer requesting checkpoint
[23:49:58] Completed 175000 out of 500000 steps (35)
[23:53:16] Completed 180000 out of 500000 steps (36)
[23:59:17] Timer requesting checkpoint
[00:01:48] Completed 185000 out of 500000 steps (37)
[00:07:49] Timer requesting checkpoint
[00:10:26] Completed 190000 out of 500000 steps (38)
[00:16:27] Timer requesting checkpoint
[00:22:28] Timer requesting checkpoint
[00:22:34] Completed 195000 out of 500000 steps (39)
[00:28:35] Timer requesting checkpoint
[00:34:35] Timer requesting checkpoint
[00:37:52] Completed 200000 out of 500000 steps (40)
[00:38:52] Completed 205000 out of 500000 steps (41)
[12:31:43] Completed 345000 out of 500000 steps (69)
[12:37:42] Timer requesting checkpoint
[12:40:18] Completed 350000 out of 500000 steps (70)
[12:46:17] Timer requesting checkpoint
[13:22:25] Timer requesting checkpoint
[13:23:45] Completed 355000 out of 500000 steps (71)
[13:29:46] Timer requesting checkpoint
[13:32:20] Completed 360000 out of 500000 steps (72)
[13:38:21] Timer requesting checkpoint
[13:40:56] Completed 365000 out of 500000 steps (73)
Pete
Pette Broad
Postby Daft Ada » Sat Jan 26, 2008 4:41 am
These things just keep coming :o
Thanks to the updated FAHMon, I'm now getting sensible readings and the PPD is over 300 :D
Edit:
They're all gone :( I've got a 2452 giving me a PPD of 40 :(
Daft Ada
Previous
