sending WU
sending WU
Postby whiteboy » Tue Jan 08, 2008 6:05 am
is there anyway to send a WU that is stuck in que?. I've had one stuck in my desktops que since early sunday morning. i'm trying to send thru the xp GUI.
whiteboy
Postby Pette Broad » Tue Jan 08, 2008 7:06 am
Any stuck WU's should attempt to autosend every 6 hours, or when you restart the client. You can also try to upload the unit by using the -send XX flag, where XX is the number of the WU stuck in the queue. What project are you trying to send?
Pete
Pette Broad
Postby whiteboy » Tue Jan 08, 2008 1:52 pm
tries restarted the interface and a complete system restart still not sending. keep getting this message in the log file:
[15:59:45] + Could not connect to Work Server (results)
[15:59:45] (171.64.122.76:8080)
[15:59:45] Could not transmit unit 07 to Collection server; keeping in queue.
unit info in que:
07 DONE "Folding@Home" (81) 171.64.65.111:8080 January 4 02:25->January 5 08:02:37
i'll try the send option next
whiteboy
Postby Pette Broad » Tue Jan 08, 2008 2:08 pm
I'm not sure what the problem is. There are 2 servers mentioned in that log, 76 and 111. I'm not familiar with 76, but it looks to be a collection server. 171.64.65.111 dishes out 41xx units and looks to be working O.K. Check you have IE set to NO in your config.
Pete
Pette Broad
Postby whiteboy » Tue Jan 08, 2008 2:31 pm
not using ie settings and havn't had a problem since i got back up into the folding game. i'll keep trying aslong as i need to was just wondering if there was another way to do it. trying the send command now and it doesn't look like it going.
4 gigs ram
2 250 gig samsung sata HDs
2 lite on sata dvd burners
whiteboy
Postby Pette Broad » Tue Jan 08, 2008 3:05 pm
O.K, I see what the problem is, a very high Net load on both those servers, I'll report it to Stanford. Luckily you have plenty of time before the deadline expires.
Pete
Pette Broad
Postby Karlsweldt » Tue Jan 08, 2008 3:05 pm
Here is a link to all the Console commands: http://folding.stanford.edu/console-userguide.html
-send x
Send result #x back to server. Exits after trying to send unit (successfully or unsuccessfully). Use "-send all" to send all results outstanding. If unit x is not a completed work unit then the client exits without doing anything.
The command line would be: [FAH504-console -send 1 { or # of WU in queue}] (or -sendall).
The Console will attempt to send a WU many times, until a set number of tries daily. It may be that the assignment server is full or down. Trying again the next day should be successful.
