It is currently Tue Aug 14, 2018 3:55 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon Dec 31, 2007 3:56 pm
That quote is what I was thinking of. Thanks for clarifying. :D
RIAA vs The People
PostPosted: Sun Jan 06, 2008 4:53 am
One other thing worth noting. If like me you switch your machines off at night and you wish to do SMP then its best to set your machines to have a static IP. Mine are setup for static in the router but you can set them through the Network Control Panel. Apparently, dynamic internal IP's can confuse the client and cause it to restart from zero. From what I can tell, if you need to restart your router and your ISP gives you a different external IP then this doesn't present a problem, its just the internal IP's that are important.
Pete
Users browsing this forum: No registered users and 7 guests
