It is currently Mon Sep 24, 2018 2:29 am
PostPosted: Wed Dec 19, 2007 2:25 pm
No! This is not off-topic, please do not move!
I'm trying to install v6 of the FAH client and add a passkey which was never used before in v5. I've got an emailed passkey from Stanford and am all set to go, but how can I copy and paste it from the email to the command prompt configuration? :?
Using the usual right-click in the command prompt does nothing and the Ctrl+V & Ctrl+C is also useless.
What am I doing wrong?
If I resort to manually typing the passkey, I'm going to be here all night, it's huge!
PostPosted: Wed Dec 19, 2007 3:59 pm
Have you tried the old-fashioned Alt+F then P key sequences? You should be able to copy it by simply highlighting the string, choose 'copy' then using the keystroke sequence.
What OS platform is used.. the true command-prompt mode is not available with XP.
Maybe you have to start the process with the similar method for the standard Console setup? {FAH504-console -configonly} or however the Console command is named.
PostPosted: Wed Dec 19, 2007 4:37 pm
No I've never seen that before. I might try it if I can't figure things out.
Yes but it doesn't work.
Whether it's "true" or "false" Windows XP does have a command prompt window in which I am trying to run the console installer for FAH.
That's exactly what I am doing.
PostPosted: Wed Dec 19, 2007 5:55 pm
Will have to look into that new console version tomorrow.
Has been a feature of all OS versions and DOS.. you 'copy' a character string or text passage, and you can 'paste' it using the Alt+F then P keystroke sequence.
I use Total Commander from www.ghisler.com/ which is great for file management/editing/creating. It has a prompt box so you can type in commands in normal manner. You can create a file very easily, if need be.. or even edit non-standard configuration files.
When bringing up the older console in -configonly mode, it will ask you for input on how you want it set up. You choose the Y/N or desired amount proposed.
Right now, the woodpile is huge.. and that chainsaw is purring...
PostPosted: Thu Dec 20, 2007 4:54 am
This is insanely, mind bogglingly stupid, but I fixed it :roll:
I was running the console installer from within Windows and it then opens itself into a command prompt window. Here I was having problems with the copy and paste nonsense.
Finally, I tried running it manually from a command line i.e. "Start->Run->CMD", and for some reason by doing this, the copy and paste works as expected.
I'm totally baffled, but problem solved.
PostPosted: Thu Dec 20, 2007 6:27 am
Most times, the simple process is the desired one!
Did a DL of the newer Version 6 Beta for the x86 platform, but not the one for the GPU setup. By using the command line to launch the Console in setup mode only, use [fah6-win-x86-console -configonly] and it will request input for your user name, team #, and other factors.. along with a passkey string if you have been given one.
Did a read-through of the exe file, and did find reference to Win 98 there. So supposedly it will run well with Win 98, but will have no recognition of any multi-core processor or the HT feature. It should work very well with W2K, XP and Vista.
Downloads of all the F@H versions for all OS types are available here.. http://folding.stanford.edu/English/Download
and for Console command use, this link.. http://folding.stanford.edu/English/WinConsoleInstall .
If you have an existing 'config' file in the folder, change its name to [client-cfg.bkp] to save the original, and not have it referenced to the newer command file. Or allow use of the previous configurations, and input the required configuration settings for the newer version.
