Wullgers milestones!
Postby wullger » Sat Feb 02, 2008 9:15 am
wullger
Postby Karlsweldt » Sun Feb 03, 2008 8:35 am
Great going!!
Your submissions are keeping us in the running.
I have just recently topped 90,000.
Please pardon his after-burner blast, everyone!
Look out, Pete! :lol:
Postby whiteboy » Sun Feb 03, 2008 9:05 am
Way to go!!! Hopefully after I get my new AMD Phenom system built, I will help push our numbers even higher, as it will be a main folder along with my cely 600, and my two xp 2500+.
4 gigs ram
2 250 gig samsung sata HDs
2 lite on sata dvd burners
whiteboy
Postby wullger » Sun Feb 03, 2008 11:34 am
wullger
Postby whiteboy » Sun Feb 03, 2008 12:23 pm
Planning on it. Question will be getting it set up to max out the potentional. being 4 cores do i run 2 smps clients or 1 smp and then 2 consoles...going to have to work on it. when i do get it in and set up, i'll start a help me max this thing out thread.
4 gigs ram
whiteboy
Postby Daft Ada » Sun Feb 03, 2008 12:36 pm
whiteboy wrote:Planning on it. Question will be getting it set up to max out the potentional. being 4 cores do i run 2 smps clients or 1 smp and then 2 consoles...going to have to work on it. when i do get it in and set up, i'll start a help me max this thing out thread.
None of the above.
SMP was designed for Quad core although it does fairly well on dual cores too. It will utilise all cores equally if you allow it to. Adding extra clients/consoles will only help to slow it down. If you slow things down too much, you'll miss the SMP deadlines and it'll just be a waste of time.
Stanford wrote:our SMP client is intended for 4 processors
http://www.stanford.edu/group/pandegrou ... Q-SMP.html
Daft Ada
Postby whiteboy » Sun Feb 03, 2008 12:53 pm
yeah i strated to research it more after i posted that. going thru all the forums i can find about folding on a phenom right now. hopefully by the middle of the month i'll have all the parts in and being built( depending when i get my refund back)
4 gigs ram
whiteboy
Postby wullger » Mon Feb 25, 2008 5:36 pm
wullger
Postby whiteboy » Tue Feb 26, 2008 2:24 pm
Got my AMD Phenom running SMP, and got my girlfriends AND X2 64 laptop running SMP. since 2-23 racked up over 9k ( including a few smaller WU's). Once I get a nice run going I'm going to try and start pumping up the speed on the phenom. currently runs a WU in about 27 hours( thats with getting in about 2-3 hours of crysis and it not turned off). girlfriends laptop is hitting it in about 55 hours. Also trying to get GPU cilent running as well but having problems with the new beta release.
4 gigs ram
whiteboy
Postby Pette Broad » Tue Feb 26, 2008 4:26 pm
whiteboy wrote: currently runs a WU in about 27 hours( thats with getting in about 2-3 hours of crysis and it not turned off)
Sounds about right, I think my dedicated 6000+ took about 30-31 hours, well under 3 days including a couple of 8 hour shutdowns.
Pete
Pette Broad
PreviousNext
