It is currently Mon Sep 24, 2018 11:37 pm
PostPosted: Wed Mar 26, 2003 4:47 pm
I saw that you had the same motherboard I just ordered as well as a similar sound system to what I want. I know it will plug in and work, however, have you been able to run everything with games alright? Has the surround sound been good with EAX supportive games and DVDs? I know that Asus says that the board supports EAX 1.0+2.0, but I wanted to see want people who had it said. Send a PM I guess if you can.
1800+Mhz AMD Athlon XP, Asus A7N8X Deluxe, Nvidia Geforce4 4800Ti, 60gig 7200RPM ATA133 HDD, 1.0 gig 400mhz DDR RAM, Volcano 11 CPU Fan, Skyhawk 4350 Alum. Case/Side window+Blue Cathode Tube
1988 Camaro Conv. with 5.0 Fuel Injected V8
PostPosted: Fri Mar 28, 2003 1:53 am
I bought the Delux Version of the Board that comes with 5.1 surround sound. So i dont know what you got. Yes when you have surround sound its easier to tell where they are but headfones are always the best. Yes the DVD movies are awsome with 5.1.
Asus A7n8x Motherboard Delux
AMD Athlon XP 2600+
1024 DDr 400 memory
Geforce 4 TI 4800 SE Graphics card 128DDR 8X
16X DVD rom Drive
Altec Lansing surround sound
Creative labs Audigy LS
Thermaltake Case 420 watt Power Supply
PostPosted: Fri Mar 28, 2003 3:29 am
You basically have a similar setup to mine, same board, similar video card, etc. Just wanted to see what someone with 5.1 speakers actually thought of the onboard sound.
PostPosted: Fri Mar 28, 2003 10:58 am
Oh ya the onboard sound is good but if you wanted name brand go with the sound blaster. I havent been able to hear a difference really but the sound is good for the extra 30$
AMD Athlon XP 2600+
1024 DDr 400 memory
16X DVD rom Drive
