It is currently Thu Sep 20, 2018 9:09 am
PostPosted: Tue Mar 04, 2003 5:58 pm
Thought I would revisit Unreal.........you guessed it problems
Running XP and have sounblaster 4.1 digitalusing the latest 226 patch for the game.
Loaded the game using the compatability option
Sound is just distorted and choppy.........orrible!
Have the latest XP drivers for sound card..........
Any suggestions, running the game in D3D have tried in game sound tweeks no change :(
Benjamin Franklin (1706-1790)
PostPosted: Tue Mar 04, 2003 11:09 pm
Need your system specs mate. :wink:
The Gift of Healing
Conscious Energy Meditation
PostPosted: Wed Mar 05, 2003 2:31 pm
1.4 gig athlon t bird, Abit KT7a socket a mobo, 512 sdram, gf4 ti4200, sounblaster 4.1 digital recently fitted, however same issue with sounblaster pci 16 card! running XP pro
PostPosted: Wed Mar 05, 2003 2:56 pm
Is this the only game that does this?
Do you have the latest SoundBlaster drivers, or are you using the XP drivers?
The Gift of Healing
PostPosted: Thu Mar 06, 2003 4:16 pm
Yes this is the only game that does this, I am using the sounblaster drivers.
PostPosted: Fri Mar 07, 2003 2:26 pm
Hi
A lot of folk seem to be having the same problem... Have you updated to the latest nVidia drivers as well?
:twisted:
i have a bad feeling about this...
MSI KT4V mobo, xp2400, 512 ddr333, 40gb 72x hdd, geforce fx 5700 ultra, 16x dvd.
PostPosted: Fri Mar 07, 2003 7:28 pm
Mmmm
I am using the 41.03 drivers, maybe I should change to see if that effects it?
