It is currently Thu Feb 21, 2019 4:13 pm
PostPosted: Sun Mar 02, 2003 10:09 am
anyone can gimme a direct link to the baltte.net update file? fanx......cause i have starcraft installed on several comps and it saves alot of time if i can just download it once, burn it and transfer it to the other computers instead of downloading it so many times.
PostPosted: Sun Mar 02, 2003 4:05 pm
Don't know where you are from, so i will Give the link to the mirrors, so that you may choose the one closest, and fastest for you.
http://www.blizzard.com/support/?id=msc0411p
WinXP Pro
1.9ghz AMD Athlon XP (barton core) OCed to 2.25ghz
Volcano 9
Abit NF7 rev. 2
512mb Apacer Infineon DDR3200 in dual channel mode
Gigabyte 5900xt
4x Aopen DVD burner
400 watt PSU
120Gig 7200rpm Maxtor
WinXP Pro
Volcano 9
Abit NF7 rev. 2
Gigabyte 5900xt
4x Aopen DVD burner
400 watt PSU
PostPosted: Mon Mar 03, 2003 12:30 am
are you on a dial up?
"[Name] masturbates so much you don't understand, if I were you I would never shake his hand." -Jin
 Post subject: reply
PostPosted: Mon Mar 03, 2003 1:41 am
yes i am on dial-up
 Post subject: oz-1 patch
PostPosted: Thu Mar 06, 2003 1:11 am
me friends tell me that the oz-1 patch is better...............anyone know the website for the oz-1 update?
