"Backing up" games?
"Backing up" games?
Postby Loki the monk » Wed Feb 26, 2003 7:54 pm
Hope this is in the appropriate thread, but can anyone tell me where i can find a really comprehensive guide to "backing up" copies of my games onto cd? i have a 52,24,52 cd-rw and clonyxxl and nero burning rom- but i only just got it and i haven't got a danny le rue how to use it!! (sorry, thats cockney rhyming for "haven't a clue")...
Ta, Loki
i have a bad feeling about this...
MSI KT4V mobo, xp2400, 512 ddr333, 40gb 72x hdd, geforce fx 5700 ultra, 16x dvd.
Loki the monk
Postby gamepyrate » Wed Feb 26, 2003 8:04 pm
well if you are trying to copy a SafeDisc protected game, the only software that CAN *not always* copy it is one that supports RAW to RAW reading/writing, which to my knowledge the only one that does this is CloneCD. Check out www.gamecopyworld.com for information on the protection scheme of your game, as most of the games you copy will need a Fixed .exe to run properly (because the fixed .exe will remember CD authentification).
gamepyrate
Postby Tolemac » Thu Feb 27, 2003 3:10 am
Loki, open up Nero and using the wizard, give "Copy a CD" a butchers. :wink:
If that doesn't do the trick, then CloneCD would be my next suggestion as well.
Tolemac
Postby stusmith8 » Thu Mar 20, 2003 9:26 am
If you are still having problems after using Clone CD then give 'Blind Read/Write Suite' a try.
ASUS A7V8X
AMD XP2000+
512mb DDR 3200 Samsung RAM
ASUS V9180TD MX440 64mb 8x AGP
Maxtor 7200rpm 120gig 8mb cache
Soundblaster Digital
52x24x52 CDR/RW
DVD Rom
ASUS iPanel
stusmith8
Return to Games
