It is currently Sun Jan 20, 2019 11:34 am
PostPosted: Wed Dec 17, 2008 8:35 pm
I'm not sure if anyone is familiar with this game but apparently several issues have been identified along in this game, namely:
usb connection lag with logitech gaming mouse (drops fps)
large pc resource consumption
I'm trying to eliminate the ping issue and make sure that my hardware is good enough to run the above game to get maximum performance i could get with minimum graphic/pc settings. My pc setup below:
mobo: a8rmvp32 deluxe
cpu: 4200+ 64x2 amd
hd: IDE connection
mouse: G9 logitech - usb connection
keyboard: ps2 keyboard cheap
gfx: 8800GT galaxy
memory: 2.5GB
Does the above setup has any instability in running such games like Fear combat?
PostPosted: Thu Dec 18, 2008 3:01 pm
Here are the minmum requirements listed on their site.
Quote:
OS requirements for F.E.A.R. Combat:
* OS: Win2000/XP
Minimum requirements:
* Processor: 1,7 GHz
* Memory: 512 MB
* Video: 64 MB
* Free space: 5,0 GB
* Screen resolution: 640x480
* DirectX 9.0c
Recommended requirements:
* Processor: 3,0 GHz
* Memory: 1,0 GB
* Video: 256 MB
* Screen resolution: 1024x768
http://f-e-a-r-combat.en.softonic.com/
Gerald Ford (1913 - 2006)
PostPosted: Fri Dec 19, 2008 11:37 pm
BANNED!
That setup is overkill for fear. You'll run it with ease.
PostPosted: Sat Dec 20, 2008 4:13 pm
What OS platform is in use.. 32-bit only, or 64-bit only, or a mid-ground compatible type? If on a 64-bit only platform, you will have problems with 32-bit only programming.
Check the Control Panel/System icon for Hardware/Device Manager. Ensure that all devices are "clean", with no warning marks. Any warning marks found, there may be a conflict or driver problem.
Also update your DirectX program to the latest for your OS type. Check also for the latest non-Beta video drivers.
PostPosted: Sun Dec 21, 2008 5:08 am
Agree there....mind you it will run with high framerates, which really makes a game enjoyable...no stuttering or lag or slowdown in explosions etc...
FEAR has a built in framerate tester/pre game running test...interesting to see how you will fair....yep get everything maxed up and I bet you will still manage 50fps minimum at best!
Now i got my new video card, must give FEAR a try once again :D
Benjamin Franklin (1706-1790)
PostPosted: Mon Dec 29, 2008 7:05 pm
I still get graphics lag every now and then on certain maps. The fps would also drop down below 50 when it happens (this happens on Minimum settings). I'm aware there are usb and sound issue at fear but I've run through the steps that overcome these issues.
I currenty use 2x1GB dual channel memory + 500MB additional.
Should I take off the additional 500MB memory to get my PC run more stable?
PostPosted: Mon Dec 29, 2008 7:06 pm
delete edit: (double posted the above accidently)
PostPosted: Fri Jan 09, 2009 5:14 pm
Might as well try, it is probably not really helping, and might even be slowing things down.
Abit KN9 Ultra
AMD X2 3800
Corsair DDR2 2X2GB
HIS Radeon 4670 1GB
Intel SSD
150GB Raptor
1TB WD Green X3
PostPosted: Sat Jan 10, 2009 1:42 pm
When using dual-channel memory setups, both 'banks' must be equal in capacity and type. Removing that extra 512 Mb module should clear up the problems. Ensure the same-color slots are used for the modules, unless otherwise noted in the mobo manual.
But the anti-virus programs have a 'screen scanner' that may overdue its protective nature.. and hold back file availability until assured the files are clean.. even if having scanned them numerous times!
Set your video aperture in the BIOS to no more than 25% of total system memory. It is an integral part of on-board video setups, as they have no dedicated memory of their own. But for add-on cards, that is only a cache to keep the video stream flowing. The OS and programming need maximum memory allocations.
Disabling any instant-messenger and 'finder' programs during intensive games can also improve frame rates. The OS is semi-dedicated to that programming aspect, and must otherwise tend to other non-essential needs.
