Crysis Crisis
Crysis Crisis
Postby arcchon » Sat Jan 19, 2008 6:30 am
Has anyone else had a problem with Crysis crashing at random times?
I can play it for five minutes or five hours and it will crash, even while I am trying to save it.
It will usually go to a blue screen, one I remember as the blue screen of death in my old computers, but then it will restart the computer, as it should.
I downloaded the patch and it has not fixed the problem, apparently.
My configuration is a follows:
CPU = Intel 6700 quadcore
MOTHERBOARD = Asus Maximus Formula Special Edition
RAM = Crucial DDR2 PC2-8500 4 GB total
HEATSINK = Thermaltake V1
OS = Windows Vista Home Premium
POWER SUPPLY = Antec 850 W
VIDEO CARD = NVidia GTX 8800 768 MB x1
SOUND CARD = SupremeFX II audio card (came with MB)
CASE = Antec 900
HD: WD 150 raptors x2 in RAID 0 and Seagate 500 GB x2, non-RAID
Any help would be appreciated; thanks guys!
arcchon
Postby Daft Ada » Sat Jan 19, 2008 9:14 am
Is Windows 32 or 64 bit?
Windows 32bit and 4GB RAM is not a good combination.
Daft Ada
Postby OldPhatDad » Sat Jan 19, 2008 11:29 am
I don't think that's so much a problem unless all four RAM slots are filled.
Antec Nine Hundred
Intel C2D E6750 @ 3.6 Ghz
Gigabyte P35 DS3L
Mushkin Redlines 2 x2GB kit
EVGA GTX 260 Core 216 896 MB
WD 250 GB SATA2
Seagate 160 GB SATA
WD 500 GB SATA2
Thermalright Ultra 120 Extreme
PC P&C Silencer 750W
Windows XP SP3
OldPhatDad
Postby Daft Ada » Sat Jan 19, 2008 11:39 am
True, hence my question.
Daft Ada
Postby Karlsweldt » Sat Jan 19, 2008 11:57 am
May well be a heat issue.. insufficient air flow by the CPU or GPU, resulting in a data 'logjam' that causes the freeze.
Try taking the case side off, and use a small personal fan (9" or so) blowing in toward the area. If no more problems, then heat is an issue. Adding some case fans for through-flow of air may be needed, or redirecting fans so they do not blow toward each other, which creates stagnation. A ratio of 1.5:1 is considered best.. with more air being blown into the case than exhausted.
Could also be a small DC fan with too much bearing friction.
Check the health of the fan when not powered.
Use a toothpick to spin the blades. If they jiggle to a stop, all is well.
If they coast to a dead stop, then the fan's bearing is dry, and needs a relube. That is easy to do.. remove the fan, and peel
the label from the back side. There should be a small rubber plug covering the bearing. One or two drops of light machine oil (NOT WD-40!!) or ATF worked into the bearing by finger-spinning the blades for a minute is all it takes. Blot out the excess, reassemble and it should be 'better than new'
Postby arcchon » Sat Jan 19, 2008 4:22 pm
It is a 32 bit system.
I will remove the extra RAM, however, it was doing it with 2 GB, as well.
I will add the extra fan, though, according to the monitoring system, I am within limits.
Still, things can never be too cool.
Oh, well, no game is perfect, as is no system.
Thanks, guys!
arcchon
Postby Daft Ada » Sat Jan 19, 2008 4:44 pm
arcchon wrote:I will remove the extra RAM, however, it was doing it with 2 GB, as well.
If it was doing the same thing with 2GB, then we need to look further. Cooling is a good start.
Daft Ada
Postby Mr T » Sun Jan 20, 2008 12:32 am
Download and run Futuremarks 3Dmark06... If it fails any test it gives a good indication of what is at fault....
Postby ssamurai26 » Sun Jan 20, 2008 5:51 pm
I don`t think it`s heat, because I have the same problem occasionally.
Abit KN9 Ultra
AMD X2 3800
Corsair DDR2 2X2GB
HIS Radeon 4670 1GB
Intel SSD
150GB Raptor
1TB WD Green X3
ssamurai26
Postby arcchon » Tue Jan 22, 2008 8:42 pm
Ready for a new wrinkle?
The original GTX 8800 was what I was going to use for a later computer in SLI; I was finally able to get two ATI 3870's and I just put them into crossfire this evening.
Now, Crysis can't be played at all!
Lost Planet also runs differently.
Wow, what a difference; I will probably just wait to play Crysis until I can get two GTX cards in SLI with a compatible board.
I guess I might have the crossfire wrong; I only using one connector between the cards, but I thought that was all that was necessary.
It's interesting to see the differences in the cards; I may just go back to the GTX and wait until I get some more money for another board, etc.
My problems may be a combination of several of the above factors; incidentally, I updated the drivers for the ATI cards (just came out 1/16/2008).
I'm thinking about just going back to a Striker Extreme and two GTX cards (and putting off a house payment or two) for now and just quit trying to go 'cutting edge' with the technology.
arcchon
Return to Games
