It is currently Tue Sep 18, 2018 7:30 pm
 Post subject: Mystery or scary games
PostPosted: Fri Nov 09, 2007 7:52 am
Hi all.
What are some real good "scare the crap out of you" games out there? I need a break from shooters and slashers.
B
PostPosted: Fri Nov 09, 2007 9:41 am
Almost every game will loose its "scare" effect on the third or fourth playing. You sort of expect the events! Any newer game that touts on AI will have more unpredictable replay results. In those versions, the sprites are randomly located, so you don't find them in the same position on every restart.
Our 'front page' will have reviews of newer games, as does 3D Gamers and other sites. Your choice as to venue.
PostPosted: Fri Nov 09, 2007 5:07 pm
Silent Hill 3 or 4. Can be found pretty cheap on e-bay. I'm playing 3 right now, and it's been real enjoyable with a PS2 style gamepad. Play it at night, with no other lights on and the sound turned up. (preferably after a few drinks too) It will freak you out.
PostPosted: Sat Nov 10, 2007 6:31 am
He he he.... I'll check itout.
Thanks all.
PostPosted: Sat Nov 10, 2007 9:39 am
F.E.A.R. and its expansions.
RIAA vs The People
PostPosted: Sun Nov 11, 2007 12:56 pm
If you like playing older classics and don't mind the dated graphics, check out Clive Barker's Undying. It's a quality game..8) Pretty scary too.
Condemned Criminal Origins is a good one also.
