Help deciding on a gamepad...
Postby SkyWlf77 » Sat Nov 11, 2006 7:04 pm
Here we go again...LOL.
I have decided that using a USB Gamepad is probably going to be easier than strictly depending on my keyboard. I have found several models with good reviews and am not sure which one to go with. Any gamers out there have any input???
1) http://www.newegg.com/Product/Product.a ... 6826127602
2) http://www.newegg.com/Product/Product.a ... 6826127207
3) http://www.newegg.com/Product/Product.a ... 6826504002
Personally, I couldn't care less about the built-in fan cooling system on the first one and I don't really need the Vibration Feedback, either. Just looking for reliability and compatibility.
Thanks in advance for the feedback!
Jason
SkyWlf77
Return to Recommendations
