It is currently Sat Dec 15, 2018 2:59 pm
PostPosted: Thu Sep 07, 2006 1:52 pm
I've got my eye on a black Lian Li PC 75 case for my next build.
http://silverpcs.com/product_info.php?products_id=105
This will be an overclocked rig using an ASUS P5W DH Deluxe mainboard with an Intel 805 Pentium D. The rig will be used mainly for digital video editing. I want at least 1TB of storage for digital video project files. An occasional high-end game such as HL 2 will find its way on the system. Standard web browsing and MS Office applications will be used.
I will initially use an air cooled solution, but adding a water block in the future is not out of the question. I don't plan on using the SLI support on the DH Deluxe right away.
[Edit: My bad. Should read ATI Crossfire, not SLI]
The only negative I have noticed on the PC 75 is lack of front panel support for audio and Firewire. I guess this reflects the age of the case. Can anyone recommend a better case for this build?
